Stan,
The location you describe sounds like 0 latitude, 0 longitude, which is just off the west coast of Africa. Sounds like the system is using this for some reason.
You can completely clear a flight plan in the flight plan menu. There is a "CLEAR FLIGHT PLAN" option. Try this, and then do a direct-to something near you, preferably using the NRST list. Let us know if this fixes it.
The other issue here is if the system has ever had a lock. You mention that you are building. Is your GPS connected, and is it getting a good signal? If not, the system may be defaulting to the last place it ever had a good GPS signal, which would be 0,0 if it has never had a signal.
The activate flight plan button is "NAVIGATE" which is highlighted when active.
