Old 11-27-2013, 06:18 AM
Stockmanreef Stockmanreef is offline
Default Wing Stand Questions
Is it OK to hang a wing in a cradle type structure before the fuel tank is in place? In other words, have the wing nose down and support wing on both ends with little support in the middle. I have the top skin on and the outboard leading edge on at this point. I have it temporarily in this state now while I rivet the top leading edge. I plan to hang it this way while I work on the other wing.
I was planning on mounting on a wall then boarding it over to protect it. Is it better to have the wing on a rolling cart? I can always make one later.
Ken
Ken Stockman
Midland, MI
EAA Chapter 1093 member
FaceBook Page: Ken's RV-14
RV-14a (serial number 140073)
N73XP
Plane at hangar and the wings ON.
Old 11-27-2013, 06:34 AM
rzbill's Avatar
rzbill rzbill is offline
The RV7 and 9 plans show an image of a wing stand. It supports the inboard part of the wing via the spar stub, not the leading edge. Your 14 plans may be similar. So, you can do as you proposed.
Secondarily, there is nothing magic about wing stand design. Make it to fit your situation. In my case, I added nests for the H-stab inbetween the two wings on my rolling stand. If I have been a little more inventive, I probably could have include the V-Stab too.
Bill Pendergrass
ME/AE '82
Old 11-27-2013, 06:39 AM
I did not see any images of a wings stand in the plans. I could have missed it.
Ken Stockman
Midland, MI
N73XP
Old 11-27-2013, 06:50 AM
Ron RV8's Avatar
Ron RV8 Ron RV8 is offline
My wings lived in this wing stand supported by the spar stub and a cradle under the second rib from the tip for about a year while I built the fuselage.
I suggest dropping a bolt through the spar stub on each side of the support to keep it from dropping off when you move it around. Don't ask me how I know...
A diagram for this stand was included in the plans for the RV-8, I don't know about the -14...
Ron Townson
Okanagan Valley BC, Canada
RV-8 Completed Dec 2013
Membership renewed Sept 8, 2019
Old 11-27-2013, 07:26 AM
rleffler's Avatar
rleffler rleffler is offline
I built my RV-10 wings stands from the following plans:
http://nerv10.com/lrosen/Construct/WingStand/index.html
They worked quite well. For the other models, I suspect all you need to do is shorten the length a bit.
bob
Bob Leffler
N410BL - RV10 Flying
http://mykitlog.com/rleffler
Old 11-27-2013, 10:13 AM
what about hanging before the tanks are attached? THe top skin is in place, so I assume that should keep any sagging from occurring.
Ken Stockman
Midland, MI
N73XP
