Originally Posted by 219PB
Pittsartist,
Did you prep your steel by removing the powder coat first? My powder coat has rust indications coming through. I am going to strip the powder coat and start over.
My steelwork was bare on arrival in the kit (which had stood for 16 years before I started). I prepped with 230 grit wet and dry, cleaned with acetone and then primed within the hour. From memory I think the primer was lechler branded - It has virtually welded itself on, very chip resistant
Richard
