Originally Posted by 219PB
Pittsartist,
How do you like the black color on the roll bar forward brace? I am doing my roll bar and canopy frame black but was not sure how obtrusive the black on the forward brace would be. Did you put a different color on the side that is visible from the cockpit?
Paul
Black's fine for me - It's actually a black epoxy etch primer that's slightly "satin" in finish similar to the Sika (so its less critical to have perfect sika lines).
I also thought the Sika would bond better to satin and that a "1 coat" paint system would have less chance of peeling under stress
Finally, I'd hoped that there was less chance of a reflection in the wind shield from the support than with say white or cream.
All good so far after about 80 hours flying.
https://vimeo.com/142061184
(you can see that I'd also struggled with smoothing the internal fillet at the base of the windscreen)
