Go Back   VAF Forums > Model Specific > RV-6/6A
  #11
Old 12-02-2013, 09:53 PM
Lars Lars is offline
Originally Posted by rstisser View Post
A few days ago I had a nasty surprise when a 20inch crack suddenly appeared right over my head in my slider after a cold weather flight. I am going to try to repair the crack with adhesive, but if that fix fails a replacement canopy will need to be fabricated. How does one remove the plexi when glued onto the frame?
Razor blade. Took me 10 minutes. Easy. After that, used razor blades to trim off the excess remaining Sika from the frame. That took longer but it was still easy. Toss the blades when they seem dull. New Sika adheres tenaciously to the old.
Lars Pedersen
Davis, CA
RV-7 Flying as of June 24, 2012
960+ hours as of June 30, 2020. Where did the time go?
Old 12-16-2013, 10:39 AM
donwmack donwmack is offline
Default sitkaflex
I did mine on my 6A slider. Only whole is for the canopy latch. Takes time, but came out great. Pics are at http://dmack.net/windscreen_glued_1.html
Don Mack
RV-6A
N708CM
Old 01-01-2014, 02:10 PM
rustyscrew rustyscrew is offline
Default Sikaflex canopy
I did my 6A slider 2yrs ago and have no problems. Would do it again.
I masked the area either side of the frame rails, applied primer after scuffing area lightly. Apply sikaflex and set frame into canopy, clamp lightly as needed.
Remove excess on both sides of rails with curved wood tool. Ensure your frame
is tweaked as needed to slide freely before you start process.
Walt
RV-6A
Old 01-03-2014, 08:48 PM
N62XS N62XS is offline
Default SIKA RULES!!
Coarse sandpaper for the powder coat, prime, glue and clamp. 50 hours on my 6A and no issues! My drilled and riveted 8 canopy had to replaced at 200 hours. It was replaced with a Todd's canopy. It was SIKAed and is still flying without issue. There is no other way to attach the canopy IMHO.
IHN,
2020 Dues Paid
Robby Knox
THEM: Why do you always carry a knife?
ME: I can't open a bag of chips with my Glock!
Old 01-03-2014, 08:56 PM
AJ85WA's Avatar
AJ85WA AJ85WA is offline
Default Check ou this thread
I would do it again the same way, it was easy if you got the patience.
http://www.vansairforce.com/communit...d.php?p=648794
AJ Wessels (Perth Australia)
Completed - RV6
http://rv6aj.wordpress.com/
Old 01-06-2014, 08:31 PM
ChiefPilot's Avatar
ChiefPilot ChiefPilot is offline
Was yours screwed or Sika'd on?
Brad Benson, Maplewood MN.
RV-6A N164BL, Flying since Nov 2012!
If you're not making mistakes, you're probably not making anything
Old 01-27-2014, 12:09 PM
Pittsartist Pittsartist is offline
Here's where I've got to - That canopy's getting bigger all the time !
Serious question - does Sika have shelf life ? (unopened)
http://www.flickr.com/photos/115470196@N06/
Old 01-27-2014, 01:26 PM
BillL BillL is offline
Yes it does have a shelf life. Google the part number and you will find technical specs on the sika site. I think I saw a year - - - I am not (yet) using it for my canopy. I am screwed up, literally, for the canopy anyway. If it cracks I will go Sika.
Question, I looked at your site and see your bird is sitting on its gear. How wide are the outside of the wheel nuts? I wonder if I will get it out of my basement while on the gear. Thanks,
Bill
RV-7
Lord Kelvin:
Old 01-28-2014, 03:03 AM
I've taken the engine and mount back off again to rivet the cowl hinges on so can't measure at the moment. The garage door and the cut lines in the concrete are 10' in the photos if that helps ?
Old 01-28-2014, 05:16 AM
Captain Avgas Captain Avgas is offline
In January 2010 you stated on VansAirforce that you had used "Goof Off" on your canopy to remove paint overspray "with no ill effects".
It may be possible that the Goof Off contained a solvent that weakened the acrylic on your canopy even though you did not know it at the time.
In reality there are very few chemicals that you can safely use on acrylic to wash/clean it without damaging it at the molecular level.
If you have applied a solvent based cleaner to your canopy previously then it may well be that your canopy would have cracked regardless of whether it was held on by Sikaflex or by fasteners.
You’re only as good as your last landing
Bob Barrow
RV7A
