Old 11-25-2013, 10:04 AM
Capflyer's Avatar
Capflyer Capflyer is offline
Default MT Prop Governor Orientation
I seemed to remember something posted about this a few years ago but can't find it with a search. The P860-4 MT prop governor I am installing when installed correctly on the engine has the actuating arm pointing down instead of up so the cable attach bracket will not work correctly. Can the entire head of the governor be unscrewed and rotated 180deg?
Mike
JAMES AIRCRAFT.com
Flying - RV8 Hot Rod "Drone Killer"
Flying - RV8 "Look'n Good"
RV4 - FAST & FUN! Rebuilt, Flown, Sold
RV-7A Built, Flown, Sold
Old 11-25-2013, 10:26 AM
Capflyer's Avatar
Found the post. Looks like all I need to do is cut the safety wire on the 6 screws holding the back plate and arm, loosen them, then rotate to my hearts content. Tighten, safety wire, move on. Sound right?
Mike
JAMES AIRCRAFT.com
Old 11-25-2013, 12:14 PM
flyinga flyinga is offline
you are correct
Jim Averett
RV-8
TS36 - Silver Wings
Fredericksburg, TX
Old 11-25-2013, 12:26 PM
BillL BillL is offline
You may have to remove the arm to install the bolt and/or make the stops work out too.
I have a Hartzell, so YMMV.
Bill
RV-7
Lord Kelvin:
