Old 11-25-2013, 09:22 AM
Mike Raviv Mike Raviv is offline
Default To be or not to be...prime?
Gents,
I live in a rather hot climate (Israel) and this is where my 7A will fly as soon as it's done. The engine is a new Lycoming YO-360-A1A. I suppose the a/c will fly once/twice a week, each week. The qustion of installing a priming system divides the crowd oppinion 50-50. So what do you say?
TNX and
BSTRGRDS
Mike
4X-ORV (res)
wanna fly next summer.
Mike Raviv, 4X-ORV (res)
s/n 70434
Installing systems.
Old 11-25-2013, 09:38 AM
Low Pass's Avatar
Low Pass Low Pass is offline
You talking fuel system or metal coating? In Israel, I'd say no on both.
Old 11-25-2013, 10:41 AM
TNX.
Since I mentioned engine type and frequency of flying - hence frequency of starting it - I thought it is obvious I'm talking priming the engine for starting it. BTW, the airframe is primered with strontium chromate, which is still legal in this country.
TNX again
Mike
s/n 70434
Installing systems.
Old 11-25-2013, 10:47 AM
rleffler's Avatar
rleffler rleffler is offline
Originally Posted by Mike Raviv View Post
TNX.
TNX again
Mike
Sorry, got tunnel visioned on the subject line. Previous reply deleted.
Bob Leffler
N410BL - RV10 Flying
http://mykitlog.com/rleffler
Old 11-25-2013, 01:02 PM
A dissenting opinion perhaps...
I've found that priming the engine helps ensure it will start more easily and will more readily achieve a steady-state near-idle RPM setting. For starts where priming isn't done I've seen some significant RPM excursions as the throttle is jockeyed to keep the engine running through the use of fuel being squirted in by the carb's accelerator pump.
Better to find the magic number of squirts of primer to use for your "average" day, and then adjust plus or minus one squirt or two for temperature variations. In the cold weather I always ensure the primer is "loaded" and ready to inject additional fuel to help the cold engine get through the initial stumbles and up to normal idle speed.
Old 11-25-2013, 06:25 PM
Robert Anglin Robert Anglin is offline
Default A witches what?
I don't know how cold your winters get there, but even if you don't get to start the engine for a longer time, say 4-8 weeks. It will help on the start up to give it a few shots. It makes the A/C worth more at resale and you may wish to go some place cold on your travels. In other words sure why not.
Hope this helps. Yours as always. R.E.A. III #80888
Old 11-25-2013, 06:45 PM
Snowflake's Avatar
An electric solenoid will keep the fuel lines ahead of the firewall, and priming four cylinders doesn't add very much weight at all. I like mine (but I do live up here in the frozen north).
Rob Prior
Old 11-25-2013, 07:15 PM
Ironflight's Avatar
VAF Moderator / Line Boy
Warm climate? We have no primers on our airplanes - a couple of throttle pumps WHILE CRANKING is all it takes for a quick start. Less equipment, fewer things to go wrong or leak. If we lived in the frozen north, I might have a different answer.
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 11-25-2013, 07:58 PM
rjtjrt rjtjrt is offline
You will rapidly get to know the exact technique your engine requires to start with no trouble.
I don't think you will need an engine primer.
Old 11-25-2013, 08:14 PM
LifeofReiley's Avatar
LifeofReiley LifeofReiley is offline
No Joy on an engine primer system...
Reiley
Retired N622DR - Serial #V7A1467
VAF# 671
Repeat Offender / Race 007
Friend of the RV-1
