Go Back   VAF Forums > Avionics / Interiors / Fiberglass > GPS
Old 11-25-2013, 04:11 AM
rjtjrt rjtjrt is offline
Default Garmin GPSMAP x96 Antenna Alignment Question
I don't think this is dealt with in the user manual, but I don't have access to my manual at present.
The antenna of my 296 can be aligned either horizontal or vertical.
Is the an advantage in terms of satellite reception of one way vs the other?
John
Old 11-25-2013, 01:18 PM
GPS signals are vertically polarized. The actual antenna elements found inside that Garmin "stick" antenna should give better performance when oriented vertically.
How much better? Will it be noticeable?
Too many other variables come into play to allow this to be quantified. Heck, even the position of your hands in the cockpit can play a roll in this equation.
Old 11-25-2013, 01:34 PM
Thanks Mark.
Aa you say not really important, but at least I now know the better of the possible orientation choices.
John
