Go Back   VAF Forums > Avionics / Interiors / Fiberglass > GPS
Old 11-24-2013, 05:27 PM
JPalese's Avatar
JPalese JPalese is offline
Default Garmin glo
Good Evening
A friend owns the Garmin Glo GPS. It is about a year old. At home, it appears charged.
However, when the power button is pushed and held to turn the unit on, nothing happens; no light , no power to unit, no comm with iPad?
Anyone have any ideas, especially the Garmin folks who hang out here?
John Palese
1) AAL Captain & Check Airman (ret)
2) USAF LtCol & Command Pilot (ret)
Active:
1) ATP / CFII ASME
2) Adjunct Professor-Aviation Science
3) MKE FSDO FAAST Lead Rep & Remedial Trainer.
RV-12 Transition Training, Rental & Instruction.
RV-6/6A, RV-7/7A, RV-9/9A transition training
RV-7 Transition Training LODA.
Drone Detection & Counter-measures
DE WB9JPH
<IXOYE><
www.facebook.com/rv12wi
www.facebook.com/rv7wi
http://www.terravigilis.com
Old 11-24-2013, 06:55 PM
g3xpert's Avatar
g3xpert g3xpert is offline
Post
Originally Posted by JPalese View Post
Good Evening
Hello John,
Your friend might try removing the battery pack for about a minute to reset the unit and then re-install the battery.
You could also try connecting to Webupdater over the USB cable and see if it is communicating and will accept a code upload.
We just released a new software update for the GLO that adds a number of nice improvements, including support for up to 4 simultaneous Bluetooth connections, so a software update is probably in order anyway.
If all else fails, call into the support desk at the number below and the people there have a lot of experience helping mobile device customers using the GLO.
Steve
Garmin G3X Support
g3xpert@garmin.com
1-866-854-8433 - 7 to 7 Central Time M to F
Please email us for support instead of using Private Messaging due to the limitations of the latter.
Old 11-25-2013, 04:20 AM
rjtjrt rjtjrt is offline
Deleted as it was inappropriate to hijack this thread
John
Old 11-29-2013, 07:01 AM
JPalese's Avatar
Thumbs up Problem Solved! Thanks.
Originally Posted by g3xpert View Post
Hello John,
Steve
Hi Steve:
Removing the battery cured the problem and the firmware has been updated. Appreciate the help, my buddy is once again a happy camper.
Old 11-30-2013, 02:50 PM
JPalese's Avatar
Exclamation Glo problem back
Hi Steve
The Glo problem I first reported has recurred.
Bad battery? Other ideas?
John Palese
Active:
1) ATP / CFII ASME
DE WB9JPH
<IXOYE><
Old 12-01-2013, 06:45 PM
JPalese's Avatar
Question The latest
Here is the update on my friend glo woes.
Battery removed again. Device reset. Problem repeated itself.
Battery removed for reset. Reset successful again. This time they left the glo powered up when it was charging and all was well.
Then they powered te glo down, hooked up charger, and le voila, the problem was there again.
Old 12-01-2013, 07:04 PM
g3xpert's Avatar
Post
Hello John,
We see from the above posting that your friend installed the latest GLO software.
A change was implemented in this software to make it more difficult to accidentally turn the GLO on (and run the battery down) when carrying it in your flight bag. Instead of just turning on when the button is pressed, you have to now press-and-hold the power button for 1 second to get it to turn on.
If this isn't the issue, please contact us by phone or email as shown below and we will work with you for a resolution.
Steve
Garmin G3X Support
g3xpert@garmin.com
Last edited by g3xpert : 12-02-2013 at 07:34 AM. Reason: Updated with information about power-on sequence.
