Old 11-22-2013, 07:19 AM
Kato's 8 Kato's 8 is offline
Default Time to fit engine cowl?
Hellooo!
Does anyone have advice on when a good time to fit the cowling is?
My new from the factory lycoming o360 is full of preservative and is mounted on the airframe. I dont know if i should drain it and start installing carb and exhaust and engine controls before I fit cowl. Is it easier to fit with more room or does all the engine componets make it more difficult?
Thankyou!
Bill
RV-8 QB Started Feb 2011
1510 hours build time as of March 2014
http://www.mykitlog.com/katocriss/
Old 11-22-2013, 07:29 AM
Jaypratt's Avatar
Jaypratt Jaypratt is offline
Default Look in fiberglass
You might look in the forum fiberglass section. 'Cowl Tool'. I put some pictures of how to do a cowl.
Better to make a spacer on your spinner bulkhead, than to use prop.
As to timing,, get it all done before you buy avionics,, wheel pants too!
Jay Pratt VAF #2
RV Central - Builder Assistance
Paul Revere, Borrowed Horse, & Shooter
