Old 11-20-2013, 08:08 PM
rswalden's Avatar
rswalden rswalden is offline
Default Tip: Easy Location of Tire Valve on Wheel Pants
Bob Walden (Waldo), CFII-ASMEL, Commercial Glider
KFFC "Falcon RV Squadron" Peachtree City, GA
RV-7A Tip-Up, IO-390, 700+ Hours
EAA/AOPA/Vans Air Force 2020 Supporter
Old 11-20-2013, 08:37 PM
guccidude1 guccidude1 is offline
Default Easy Location of Tire Valve on Wheel Pants
I like the way you did that. Now, just take some bright colored spray paint and make a mark on the both the inside and outside of the tire bottom. With that done, you can tell when the valve is aligned with the very clever hole. When the paint mark is visible on the bottom of the tire whether pulling or pushing with a tow bar or rolling the tire from the side. Dan.
Old 11-23-2013, 10:06 AM
acroflyrgirl acroflyrgirl is offline
Default Tire marks
So, what can you use to mark the tire? I've been using tire chalk, but it doesn't last very long.
Old 11-23-2013, 10:14 AM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Wet suit paint might stay on?
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 11-23-2013, 10:16 AM
Mike S's Avatar
Senior Curmudgeon
Bob, into stargazing by any chance??
Mike Starkey
VAF 909
Rv-10, N210LM.
Old 11-23-2013, 10:40 AM
N15JB N15JB is offline
I just used a can of spray paint from HD; don't remember the brand, but it is still very visible after 4 years.
Jim Berry
RV-10
Old 11-23-2013, 10:45 AM
pierre smith's Avatar
Whiteout from the stationery dept.
Best,
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
Old 11-23-2013, 01:35 PM
fl-mike's Avatar
fl-mike fl-mike is offline
Sharpie makes a wide tip paint pen. Get at the local craft store. I use yellow.
Mike W
Venice, FL
N164WM
Old 11-25-2013, 06:47 PM
erikpmort's Avatar
erikpmort erikpmort is offline
Can I ask what kind of cap you used to seal the hole ? Thanks for this post we have been thinking about this problem
Erik Mortenson
Rans S-20 low and slow
14 build working on wings
Old 11-25-2013, 07:15 PM
LifeofReiley's Avatar
LifeofReiley LifeofReiley is offline
Default We use these...
http://aircraftproducts.wicksaircraf...ilter=&by=prod
Reiley
Retired N622DR - Serial #V7A1467
VAF# 671
Repeat Offender / Race 007
Friend of the RV-1
