Old 11-19-2013, 05:53 PM
Ron B. Ron B. is offline
Default #33 dimple
On the RV-14 trim tab, Van's ask for you to dimple the #33 holes. I don't see Averytools listing a #33 dimple die. Would a #30 die work for these rivets?
Ron
Thanks Ron
RV-10 SOLD
RV-14 Flying
AirCam flying
Old 11-19-2013, 06:17 PM
agirard7a's Avatar
agirard7a agirard7a is offline
Default What is going in the dimple?
A rivet, what size? Or a #6 or #8 screw?
Al Girard, Newport, RI
N339AG
RV-9
Old 11-19-2013, 06:27 PM
Bob Kuykendall's Avatar
Bob Kuykendall Bob Kuykendall is offline
Default MK319BS?
Originally Posted by agirard7a View Post
A rivet, #6 or #8 screw?
Probably an MK319BS c'sunk Monel pop rivet, which has a nominal shank diameter of 7/64".
I don't know if it's the exact right thing to do, but I usually drill and dimple those #40 so I can use -3 clecos, and then drill them up to #34 or #33 on final assembly.
Thanks, Bob K.
Bob Kuykendall
HP-24 kit sailplane
EAA Technical Counselor
Old 11-19-2013, 06:39 PM
The holes are for a pop rivet ,to which I do not recall the type or size. Possible a MK-319-BS?? I'll check tomorrow when out in the hangar.
Thanks Ron
RV-10 SOLD
RV-14 Flying
AirCam flying
Old 11-19-2013, 06:56 PM
I went out to the hangar and checked. Yep MK-319-BS. I tried one in a dimpled #40 hole and fits perfect. I'll use a #40 dimple die.
Thanks Guys
Thanks Ron
RV-10 SOLD
RV-14 Flying
AirCam flying
