Old 09-04-2006, 11:18 AM
mikehoover's Avatar
mikehoover mikehoover is offline
Default Low oil pressure light recommendation
Any specific light model number/stock number and vendor for a low oil pressure panel light to use with Vans Hobbs and pressure switch set up?
Thanks!
Mike Hoover
Columbia, SC
www.aclog.com/rv-9a/
www.eaa242.org/
N194MH first flight on 08-26-12
Old 09-04-2006, 01:52 PM
Ironflight's Avatar
VAF Moderator / Line Boy
Default Might think LED
This is so simple to do with an LED and dropping resistor - and it will never burn out - that I'd just visit an electronics part store (or a Radio shack if you have to ) and pick one up. I used all LED's in my annunciator panel, and should never have to worry about replacing them.
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 09-04-2006, 02:46 PM
mikehoover's Avatar
Default LEDs
Thanks for the reply. I would prefer LEDs since I learned about them a while back and am using them for position lights. However I don't know what I'm doing with them - just need a kit. If I go to Radio Shack, what do I need? A red LED and a certain kind of resistor. Regulator? Any schematics for this?
Thanks!
Mike Hoover
Columbia, SC
www.eaa242.org/
Old 09-04-2006, 03:09 PM
Richard Suffoletto
Posts: n/a
Radio Schack sells LED light assemblies with the resistor built in.. Just hook up to 12 -14 v. They have a selection in red, green, yellow, etc....
Old 09-04-2006, 03:10 PM
OneTwoSierra OneTwoSierra is offline
I like the bayonet holders from RadioShack here with a Super Bright LED, bayonet style here. The bulbs are 12V with a resister built in. You can go to regular bulbs if you want.
