Other options
I just removed the 4 studs from my prop governor flange and replaced them with longer studs for my new Hartzell prop governor. I was concerned about messing up a stud but it turned out to be simple to remove the old studs and simple to install the new longer studs. Used the two nuts tightened against each other method for both the removal and installation steps. Just another option to consider.
Another option, stick a B&C SD-8 backup alternator on the vacuum pad.
Regards,
Thomas Velvick
Goodyear, AZ (KGYR)
2020 Donation sent.
N53KT RV-6a finished 2018, Flying
N7053L RV-4 Wife's RV
N56KT RV-4 Finishing
