Old 11-17-2013, 07:05 PM
ChuckC ChuckC is offline
Default First Engine Start a No Go - Got Brrrrrrrr
Filled engine with coolant. Filled engine with oil; pressurized and got 30psi when spinning prop. Filled gas tank with two gallons. Got fuel pressure. Turned on master, throttle full idle, choke on, Skyview on showing oil and fuel pressure, both ignitions on, turned starter key and got Brrrrrrrr sound. Engine did not turn over or start. Checked fuses and none were blown. Battery at 12.5v. Tried to start engine again with no choke and full idle; still got Brrrrrrrr sound with no prop turn or engine start. Any suggestions on what to look for to get the engine to start?
Chuck Carlson
120445
Old 11-17-2013, 07:19 PM
JBPILOT JBPILOT is offline
Default Please explain your - -
Brrrrrr sound. Sound like a starter motor turning, or are you describing something else ?
John Bender
Flying RV-12 - Serial #120036
Paid in May ( 5-2021 )
Old 11-17-2013, 07:28 PM
Sounded like a rivet gun.
Chuck Carlson
120445
Old 11-17-2013, 07:32 PM
RFSchaller RFSchaller is offline
Sounds like the starter gear is not fully engaging.
Old 11-17-2013, 07:35 PM
So, pull the starter?
Chuck Carlson
120445
Old 11-17-2013, 07:42 PM
Chuck,
I would start with some research in the line and heavy maintenance manuals.
Rich
Old 11-17-2013, 08:22 PM
rvbuilder2002's Avatar
If it is a new engine, I would start with a call to a warranty service center (Lockwood, etc.)
The sound you are describing is the same as that made by a bad starter motor sprag clutch. Highly unlikely on a new engine I would think.
Scott McDaniels
Hubbard, Oregon
FAA/DAR
Old 11-17-2013, 08:31 PM
Default Your description sounds like - -
a solenoid chattering. Make sure your battery connections are all very solid. Put a volt meter on the starter lead and see what the voltage is during the clattering sound.
John Bender
Old 11-17-2013, 08:34 PM
Yes, a brand new engine. Never started before. Good idea.
Chuck Carlson
120445
Old 11-17-2013, 08:36 PM
roger lee roger lee is offline
It still could be a poor battery or its connection. It could also be wired wrong somewhere.
It could possibly be the starter solenoid.
Roger Lee
Tucson, AZ
