Old 11-17-2013, 02:45 PM
swisseagle's Avatar
swisseagle swisseagle is offline
Question Front center baffle, cut off this area?
Hello
Finishing the baffle, now the question, what should I do with the marked areas?
Can I cut these off or are they needed to block the top/bottom half?
Thanks for any input.
Dominik
RV-7A, TMX-IO-320, FM-150, Sensenich FP
Flying since 28. April 2016
Old 11-17-2013, 04:46 PM
ILikePike ILikePike is offline
Default Good question
I would like to know that myself. I set a new world record today working on the front baffles and snorkel. I am certain no one has installed and removed a cowling more times than I did today.
Jeff Green
2016 RV-8 #82985
1968 E33C Aerobatic Bonanza
Pleased to donate Dec 2019
Old 11-17-2013, 06:29 PM
Kahuna's Avatar
Kahuna Kahuna is offline
Originally Posted by swisseagle View Post
Hello
Cut........
Kahuna
6A, S8 ,
Facebook, Track Me
Gold Hill, NC25
Old 11-17-2013, 07:51 PM
roee roee is offline
Lightbulb Trim, but trim wisely
Those marked sections don't do anything to separate the high and low pressure areas in the cowling. They just uselessly hang there inside the low pressure area.
So I trimmed them back, although for structural reasons I didn't remove all of the material that you marked. I left a little bit of material in triangular sections that still contribute to the structural integrity of the baffling. It's not so much that they're acting as gussets per se (although they do add a little rigidity), but that by leaving that material there I prevented the creation of stressed inside corners that could initiate cracks.
Roee Kalinsky
San Diego, CA, U.S.A.
RV-7A under construction
www.kalinskyconsulting.com/rvproj/
Old 11-18-2013, 03:49 PM
swisseagle's Avatar
Default Will cut a bit ...
Thanks for your answers!
Ok, I will cut a bit off, make big radius and fine it is.
Dominik
