Old 11-16-2013, 04:38 PM
airguy's Avatar
airguy airguy is offline
Default Oxygen sensors
You guys that are running O2 sensors for AFR monitoring - what model are you using? I would like to install one while I'm doing my FWF work now, rather than later.
I will see occasional 100LL use and I understand the sensors have a limited lifetime with lead exposure, but the majority of this engines life will be burning 91 mogas.
Old 11-17-2013, 01:17 AM
KRviator's Avatar
KRviator KRviator is offline
Mark Langford or KR2 fame did a decent writeup on installing one on his Corvair. His O2 sensor (that I plan to use eventually as well) is Bosch part number 11027.
Once you have tasted flight you will forever walk the earth with your eyes turned skywards, for there you have been and there you will long to return - Leonardo DaVinci
My Flickr gallery: http://www.flickr.com/photos/35521362@N06/
RV-9A - Finished on 10th February 2016 after 4 years, 9 months and 19 days! The 1020th RV-9 flying.
First flight 26th March 2016. Essential specs 145KTAS @ 2400RPM, 8000', 24.2LPH, Initial RoC 1800FPM.
Old 11-17-2013, 06:17 AM
jetdriven jetdriven is offline
1-wire O2 sensors are only accurate right around 14.7:1 AFR, outside of that they are useless. They produce 500mV at 14.7:1, but go to zero or 1V within a couple tenths and it is not linear. You may know you are richer or leaner than 14.7, but that's about it.
The wideband kits, such as the Innovate LC-2 show true AFR from 10:1 to 20:1 and they are accurate across the entire range. . I have one on my turbo Eagle Talon. It also has the 2" gauge as well. The replacement sensor is around 40$.
Byron
1977 Mooney 201
Houston, TX
Old 11-17-2013, 10:23 AM
BillL BillL is offline
The Innovate site shows the bosch (LSU4.2) wide A/F sensor is $79. Do you have another source for that one? That is still a good price as an ND brand wide A/F sensor for my Toyota is $165 as a "will fit" part from Advance Auto.
Bill
RV-7
Lord Kelvin:
Old 11-17-2013, 10:37 AM
DonFromTX's Avatar
DonFromTX DonFromTX is offline
I acquired a couple Bosh 02 sensors for free, the number on the side is: 05149263AA ABASZ 0258 017 212 LSU 4.9 203125 06 982 /6.
Problem is, there are 6 wires coming out of it, not sure which ones to use. Anybody got a clue?
A&P, PP-SEL, Pathological Flier, EAA Technical Counselor
EAA Chapter 595 President,http://www.595.eaachapter.org/index.htm
Retired US Army Officer
Old 11-17-2013, 06:06 PM
Does this help?
http://www.boschautoparts.com/BAP_Te...allGDWEB09.pdf
Maybe this is better:
http://www.megamanual.com/PWC/wire.htm
Bill
RV-7
Lord Kelvin:
Old 11-18-2013, 09:49 AM
Innovate uses a Bosch 17014 sensor. you can get it for 50$ at Amazon and others.
http://www.mye28.com/viewtopic.php?p=897048
Byron
1977 Mooney 201
Houston, TX
Old 11-18-2013, 11:29 AM
DonFromTX's Avatar
That was a big help Bill, thanks a lot for the information.
Old 11-18-2013, 02:26 PM
airguy's Avatar
So the wide-band sensors, they just put out a variable voltage that linearly relates to the air-fuel ratio, is that right? What I'm wanting to do is feed this into one of the general-purpose inputs on the Dynon Skyview for a display widget so I can see what the AFR is in realtime.
Old 11-18-2013, 05:12 PM
You still need a controller such as the LC-2 to provide the output, but yes they linearly put out 0-5V natively for AFR. You can also configure the software to put out 0-1V and substitute that for the factory narrowband sensor in cars, or for other uses. You could feed the 05V or 0-1V output to anything that will accept it and calibrate it for voltage to AFR.
Byron
1977 Mooney 201
Houston, TX
