Old 11-16-2013, 03:01 AM
AV8AZ AV8AZ is offline
Default Back rivet plate + projected target light?
While back riveting on a bench and the plate is hidden by the part, there is the risk of misjudging the location of the plate and striking a rivet off the plate.
Has anyone tried something like using a narrow-beam light source fixed above the bench aimed at the plate? This would illuminate the area on the part being worked under which the plate is located. If neither the light source or bench moved, this would seem to be a reliable way to not "miss" the plate.
Are there other more simple solutions to reduce the risk of this happening?
Old 11-16-2013, 04:45 AM
newtech's Avatar
newtech newtech is offline
Sounds like a good idea to me; yes, I did drive a couple of rivets off the side of the back rivet plate. Luckily, in my case, it was survivable.
______________________
Steve Eberhart, W9JUQ
3EV - Evansville, IN
Where is Steve and the Sky Terrier?
RV-7A Slider, O-360 A1A, Catto 3 blade, 2 screen Garmin G3X Classic, GTN 650, Bionics APRS. FLYING since June 24, 2009
EAA Chapter 21
Old 11-16-2013, 07:13 AM
JanRV6UK's Avatar
JanRV6UK JanRV6UK is offline
On my back riveting table I projected out the 4 corners of the steel plate'. That made it easy to see that I was inside the back rivet plate surface ...
Jan
Slooow RV6, no hole, builder in UK
Paid up for 2015 ...
Old 11-16-2013, 09:07 AM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Default Welcome to VAF!
Tyson, welcome to the good ship VAF
Interesting idea of using lights--------I just used a really big back rivet plate, and ran blue masking tape lines to show the borders of the plate.
I think your light idea may be a better solution if it is done right.
Good to have you aboard.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 11-16-2013, 11:47 AM
If you look up the U tube videos that Cleveland tools recently started, they show using a crossed set of laser pointer lines to help find the die when dimpling large sheets with a C frame or drdt. I think you could apply the same gizmo to a backrivet bench.
