Old 11-14-2013, 10:11 PM
Valentine Valentine is offline
Default Nose gear adjust - 6a
22 to25 lbs but measure where, how?
Hal
Finally sold N7HK
Old 11-15-2013, 06:25 AM
painless painless is offline
I use a fish scale, hooked onto a piece of music wire (could even be a piece of coat hanger) that is looped under the axle bolt head before the nut is tightened down. Pull on it perpendicular to the nose wheel.
Jeff Orear
RV6A N782P
Peshtigo, WI
Old 11-15-2013, 09:23 AM
pierre smith's Avatar
I used a 3/8" drive socket on a 6' extension and stuck it through the wheelpant, onto the axle bolt head. Picked up a bathroom scale and held the face of it vertically against the extension and pushed and read the pounds.
Best,
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
Old 11-15-2013, 03:05 PM
RONSIM's Avatar
RONSIM RONSIM is offline
Default Walmart Fish Scales
Just did mine ------ as posted before, but the fish scale hooked right up --- set mine to 28lb, tire at 42lb and cured nose wheel shimmy.
RV-10 Co-built, maintained, flown (sold)
RV-8A Maintained and flown (Sold)
RV-6A Bought and Flying (N177RV), upgrades $$$
IO360, 180HP/CS, AFS 5600T, D10A, G650, G430, G327, ADS-B, VIZ385 AP
Very Happy Contributor
Comm, SMEL, CFII, A&P
Based at KCLW (Clearwater, FL)
