Old 11-13-2013, 11:13 AM
airguy's Avatar
airguy airguy is offline
Default Vetterman crossover hanger locations?
I've searched and searched, but can't find any good pictures showing the locations of the exhaust hangers. Maybe I'm looking in the wrong places...
IO360M1B with Vetterman crossover, I understand the hangers should be to the block instead of the engine mount to cut out the relative movement, but I'm looking for where to clamp on the exhaust and where to bolt on the engine.
TIA...
Old 11-13-2013, 11:19 AM
turbo's Avatar
turbo turbo is offline
i have been clamped to the engine mount with no problems.
TURBO YES =VAF= Payed Jan2019
Ed D'Arcy
addicted pickle ball player
Old 11-13-2013, 02:54 PM
seattleworm seattleworm is offline
I just did the exhaust hanger last night (I also have IO-360-M1B). I did it per the simple instruction coming with the vetterman exhaust. I used the two of the fasteners on rear oil sump flange. There are total 6 fasteners on the rear sump flange, 4 in the center are more aft than the two outboard fasteners. I used the outboard two of the 4 center ones. I had to loosen the nuts and bolt on the bent tabs coming with the hanger kit. Following link is what I found from Matt's site, he used the center two fasteners due to interference with control cables.
http://www.rv7blog.com/2011/07/10/ex...pipe-supports/
Shawn Li
RV-7-First Flight 5/27/2014
RV-10, Tailcone completed, wings in work
