Old 11-12-2013, 05:21 AM
Don Patterson's Avatar
Don Patterson Don Patterson is offline
Default New cylinder installation
Doing a top end on my IO-360 and installing new Lycoming cylinders along with new pistons,rings and valves. What would the proper method of breaking in the cylinders and should I use mineral oil.
Don Patterson
RV-7A Slow Build, IO-360, Hartzell constant speed blended airfoil. CFII
First Flight Oct 6, 2010
Old 11-12-2013, 06:51 AM
Walt's Avatar
Walt Walt is online now
ECI has a well written set of break in instructions.
http://www.eci.aero/pdf/BreakInInstructions.pdf
A google search of Lycoming cylinder break in will give you lots of info.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 11-12-2013, 07:07 AM
DanBaier's Avatar
DanBaier DanBaier is offline
Also a Lyc Service instruction - a copy is available on line at http://www.lycoming.com/Portals/0/te...onsumption.pdf
Dan
RV7A (N7101) - Flying 10/2008
CFI- SE/ME/Inst
A&P
KC2ZEL
Old 11-12-2013, 06:40 PM
Default Cylinders
Thanks for the response guys, I will down load them tonight.
Don
Don Patterson
