Originally Posted by rickmellor
Joe,
Are there any issues with fuel purging overboard when you tee into the vent line? I like the idea of saving a line run to the tank, and I much prefer this over purging back into the intake lines. I just don't want to spit gas out on the ground everytime I start the engine.
-Rick
Rick,
First of all, you are not purging the fuel overboard.
Most if not all simply returns to the tank you have plumbed into. I haven't noticed much of a fuel drip coming from that tank vent during the purge operation. If you select the same tank when you do the purge procedure (which I do), then you have a continuous loop and little if any fuel drips. I have seen this done on several aircraft and it works fine. Also, you will only need to do this procedure on rare occasions when it is very hot out and you have just flown, shutdown and let the plane sit for a while. This may have to be done more in warmer climates than we have up in the NW.
Joe
