11-10-2013, 02:31 PM
Strobe wire cable
I am getting ready to pull in some wires and was wondering...
Should I substitute the cheesy strobe wire cable that came with my Strobes n' more kit with some real airplane MS27500 multi conductor 16 AWG cable instead?
The 27500 will be smaller in the bundle. I am also wondering if it will be elecronically quieter as well?
I know that the MS stuff is better for many reasons, but what about the dielectric strength with respect to the high voltage nature of the strobe circuits?
What are your thoughts?
 CJ
The experiment works!
11-10-2013, 02:39 PM
This is the stuff that comes with the kit...
It just doesn't look aviation grade to me!
 CJ
11-10-2013, 02:41 PM
Either way...
SHOULD you or COULD you? Sure, you can, but it's not absolutely necessary. The wire that comes with the Whelen units (assuming that's what you're using) has worked flawlessly for years. Larger aircraft use the M27500.
Just make sure you ground per the instructions....if I remember, just at the power supply end.
Jeff Atkinson
RV-8 #82594 Flying since May 2012
Barrett XP-360, Catto 3-Blade, Dual G3X Touch, GTN-650, VP-X
11-10-2013, 02:47 PM
The cable supplied with my Whelen strobes looks exactly like that...I'm sure it's fine.
RV-8 #81077 Super Slow Build
Dynon Skyview HDX, Titan IOX-370, Dual P-Mags, AFP FM200A FI, Whirlwind 200RV CS Prop
First Flight 11/20/2016
www.marksrv8.com
11-10-2013, 03:42 PM
That wire that came with your strobes n more or Whelen lights is PVC coated. The mil speck wire is tefzel. I just replaced my PVC cable when I changed my lights to the LED variety from AeroLed. Cable lengths were different, eliminating the power supply. I used 20 awg tefzel cable (from Stein) as spelled out in the instructions from AeroLed. I don't think it made any difference, but it is definitely much smaller in diameter.
SH
RV6/2001 built/sold 2005
RV8 Fastback/2008 built/sold 2015
RV4/bought 2016/sold/2017
RV8/2018 built/Sold(sadly)
RV4/bought 2019 Flying
Cincinnati, OH/KHAO
JAN2020
11-10-2013, 07:07 PM
I used the cables that came with the strobes n more kit. No problems with wear of the cables or noise in 4 years or 125 hours. Just one point of reference.
Jay Martin
RV-7A Flying
N7721J
O-320 160HP
Sterba Prop
11-11-2013, 08:44 AM
Hmmmm...
Thanks guys!
I am just going to use the grey PVC stuff that they supplied with the kit. Seems like it will work fine and I already have it on the shelf.
Nuttin' to it but ta do it!
 CJ
