11-10-2013, 01:37 PM
mag question
So I sent my slick mags in for the 500 hour inspection, no problems getting them off. When I took them off, I rotated the prop until the 25 degree mark was at the split in the case. However, I used the mark on the outside(next to the spinner) of the starter ring and not the inside. My question is when I put the mags back on should I align the timing mark with the starter hole or leave the prop in the present position. I understand about using the slick pin to hold the gears in place, but I didn't want to screw anything internally on the engine. Thank Randy
11-10-2013, 02:49 PM
#1 cylinder TDC, starter pin hole
TURBO YES =VAF= Payed Jan2019
Ed D'Arcy
addicted pickle ball player
11-10-2013, 03:10 PM
Senior Curmudgeon
This mark lines up with a pin you insert into a hole in the starter, NOT the crankcase split.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
11-10-2013, 05:29 PM
Also, you cannot time close enough just by placing the prop at the mark and sticking the mags on. That's really just to get you on the correct tooth. You need to install the mags then use a timing light or else yo uh may wind up quite a few degrees off.
Actual repeat offender.
11-10-2013, 07:29 PM
Number one at 20 or 25 degrees depending on engine BTDC lined up with the starter hole, that's how I do it anyway.
11-10-2013, 08:12 PM
Slick Timing
Randy: You can use either set of timing marks to install your mags. I like to mark the front side of flywheel tooth that lines up with the 25 deg mark on the back side of the flywheel. This way you can stand in front of the engine and line up this tooth with the crankcase split. If you use a black sharpie your timing mark will likely be there next year. Using the 25 deg mark on the front side of flywheel and lining it up with the starter hole works fine and does the same thing. This will get you in the ballpark to install the mag and a timing light will allow you set it where it needs to be. DO NOT turn the prop with the timing pin in the mag. DO use the correct gaskets, lock washers and torque. Send me a pm if you need assistance.
Don B
RV 9 Engine Build in Progress
A&P, IA ect.
11-21-2013, 05:20 AM
I saw a variety of answers on this thread that conflict. So for clarification, when installing the magneto should the engine be set to TDC or 20/25deg (per eng spec) using the timing marks aligned at the starter pin hole?
Mike
JAMES AIRCRAFT.com
Flying - RV8 Hot Rod "Drone Killer"
Flying - RV8 "Look'n Good"
RV4 - FAST & FUN! Rebuilt, Flown, Sold
RV-7A Built, Flown, Sold
11-21-2013, 06:10 AM
Set the engine at 25DBTDC or 20/22 or whatever is required based on C1.
______________________________
David Brown
DYNON Authorised Dealer and Installer
The two best investments you can make, by any financial test, an EMS and APS!
11-21-2013, 06:29 AM
The link is to an article on how to install a magneto.
http://www.aviationpros.com/article/...tallation-tips
Bill Peyton
RV-10 - 1125 hrs
N37CP
First Flight Oct 2012
Aviation Partners, LLC
11-21-2013, 09:27 AM
Originally Posted by Bill.Peyton
I think this is one of those cases that the more you read, the more one gets confused.
The article on the second page indicates
"slowly continue to turn the prop until the timing mark listed on the engine data plate lines up exactly with the split line on the top of the crankcase for Lycoming engines or the split line on the bottom of the crankcase for Continental engines. "
Are most Lycomings timings are done based on the split line on the case and fewer are based on the small hole onthe starter?
Mehrdad
N825SM RV7A - IO360M1B - SOLD
N825MS RV14A - IO390 - Flying
Dues paid
