Go Back   VAF Forums > RV Firewall Forward Section > Propellers
Old 11-10-2013, 04:34 AM
jaredyates's Avatar
jaredyates jaredyates is offline
Default Woodward RPM adjustment
I have a woodward governor and would like to adjust the high RPM stop screw. I can't find directions, but I was hoping that the Woodward folks designed it so there would be a certain number of screw turns associated with a certain number of RPM, so that I wouldn't have to stab in the dark. Does anyone know if there is a relationship, or does anyone remember the results of making an adjustment in the past?
Old 11-10-2013, 05:23 AM
Walt's Avatar
Walt Walt is offline
Expect about 25 RPM per screw revolution.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 11-10-2013, 10:32 AM
jaredyates's Avatar
Default Thanks!
Thanks! That will save me some time for sure.
