Old 11-07-2013, 10:43 AM
N787KV N787KV is offline
Default Lycoming gasket need
Does any one know where I can find the gasket that goes between the snorkel and fuel servo on a IO360. Part number I was told is 775504
Peter Richmond
RV-7a, N787KV - sold
Old 11-07-2013, 01:43 PM
EAGLE BOB EAGLE BOB is offline
Default Gasket - Wrong Part Number
I believe the gasket you are looking for is a 77504 and can generally be purchased at any engine shop or Spruce.
Old 11-07-2013, 02:21 PM
Bavafa Bavafa is offline
I don't have a gasket between the snorkel and fuel servo, but there is a gasket between the servo and the engine block.
Mehrdad
N825SM RV7A - IO360M1B - SOLD
N825MS RV14A - IO390 - Flying
Dues paid
Old 11-07-2013, 04:00 PM
jrs14855 jrs14855 is offline
Default gasket
The gasket between the injector and the air inlet is an airframe manufacturers part. Any Piper or Cessna parts book using a similar engine will get you the pn.
Old 11-07-2013, 11:25 PM
Default Thanks
I had to many 5's. The correct Lycoming number is 77504.
Peter Richmond
