Vref uses cost of overhaul or factory reman divided by TBO.
Let's say a new Lycoming IO-360 was $37,000 with a 2000 TBO, that's $18.50 per hour.
In your example, the 400 hr engine would be worth $18,500 more than the 1400 engine.
Use new, factory reman, or field overhaul as your base value depending on circumstances.
Don
RV-8 QB Titan ECi 191HP XIO-360
WW200RV Dynon D180 HS34 AP74
GNS430 SL30 GTX327 PS8000B Uavionix Echouat
"Pilots are alchemists... we turn gold into lead."
