landing short
I have landed my -8 on a relatively short (for a RV) back country strip in Utah with high bushes near the end. The strip is around 4000' feet in elevation. I practiced quite a bit before bringing it in there using the powered/drag it in approach technique. The trouble with this is that the pitch angle to maintain just above a stall with power and a decent angle to clear the bushes was substantially nose high, wiping out forward visibility which then made a spot landing difficult. It was also then difficult to judge my wheel clearance over the tall bushes. I landed to a full stop in about 600 ft from the end.
I have since had better success approaching at about 60 to 65 kts in a steep enough angle to clear a obstacle, then chopping the power completely so that my prop is as idle as possible at touchdown. This requires good timing and accurate pitch adjustment to touchdown firm but not hard.
With a fixed pitch prop, the windmilling effect really hurts the deceleration, so having the prop "unwound" as possible at touchdown helps substantially.
