Old 11-05-2013, 07:02 PM
Ron B. Ron B. is offline
Default Canadian pre cover
I'm building an RV-14. With wings ready for pre-cover inspection and tail kit soon to be completed I thought I would be able to get the pre-cover inspections out of the way. I'm being told that the fuselage will require a pre-cover as well. I don't recall getting a pre-cover on the RV-10 ( we might have , I will look that up) . Any other Canadians out there that remember having a fuselage pre-cover done by MD-RA? Other than under the baggage floor and by your feet floor , everything else should be visible at final inspection. The floors are pop riveted if I remember correctly.
On my SuperCub fuselage, there are many places that cannot be seen when finished so I understand a pre-cover there.
Thanks Ron
RV-10 SOLD
RV-14 Flying
AirCam flying
Old 11-05-2013, 07:09 PM
Ron RV8's Avatar
Ron RV8 Ron RV8 is offline
Yup, they want to look at the fuselage too. I got the whole thing done at one visit, expensive enough as it is. Don't cover anything up or I understand they'll make you take it apart again... If the floors are the only factor, maybe put them in after... Final inspection should be ready to fly. Any doubts, talk to MDRA to clarify.
Ron Townson
Okanagan Valley BC, Canada
RV-8 Completed Dec 2013
Membership renewed Sept 8, 2019
Old 11-05-2013, 07:10 PM
Default Ron
I saved some coin by calling in my MD-RA inpector to inspect my entire QB
RV7a at one time. So, wings, emp and fuse were done in one visit............
one invoice.
Lorne
RV 7a tip-up
Pre-cover MD-RA Inspected.
Old 11-05-2013, 08:45 PM
Larkrv10 Larkrv10 is offline
Default pre cover
Ron, I certainy had a pre cover inspection on my RV10 fuselage (last summer) by the MDRA. We placed the sticker up under the rear seat back supports. It was a relatively easy inspection compared to the wings and tail.
Good luck with the new project.
Rick
#40956
Southampton, Ont
Old 11-06-2013, 08:51 AM
Similar response for composite fuselages... I had to have a pre-cover inspection done on our Glasair Sportsman fuselage, even though the aluminum flight surfaces had previously had a pre-cover inspection done.
Old 11-06-2013, 09:35 AM
Paul Tuttle's Avatar
Paul Tuttle Paul Tuttle is offline
Ron,
Wayne came over to the shop and did the pre-closing inspection on the tail, wings, and fuse all at the same time. I didn't see him again until the final inspection.
Paul Tuttle
RV 8
C-FPVT
Flying.
Old 11-06-2013, 11:03 AM
Champ's Avatar
Champ Champ is offline
Default Cdn Precover
I had my RV-8 fuselage in progress when the wing precover was done. My MD-RA "requested" another precover on the fuselage prior to putting the top skin on. His reason was that it would be to difficult to get inside with the top skin on and all the way back to the tail. So, I payed for a second precover. I have had to crawl down there many times since, but I'm not a big guy.
Dennis Enns
Kingsville, ON
Bellanca Champ 7ACA since 1986, restored 1990.
RV-8 IO375, Hartzell CS, dual PMags.
2020 Donation In
Old 11-06-2013, 11:25 AM
n82rb's Avatar
n82rb n82rb is offline
justa curious guy from south of the frozen line, what does this pre-cover usually cost?
bob burns
RV-4 N82RB
Old 11-06-2013, 12:40 PM
Don Patrick's Avatar
Don Patrick Don Patrick is offline
Default Big bucks
$395 plus taxes, then the inspectors mileage to come and go to the inspection location. Usually around $500 in total.
DP
RV-8 build
DONE!
C-GLOV
http://www.mykitlog.com/Don%20Patrick
Old 11-06-2013, 01:21 PM
DP
That's for each visit.
So you see why many of us try to get it done in one inspection.
Lorne
RV 7a tip-up
