Old 11-03-2013, 03:22 PM
s10sakota's Avatar
s10sakota s10sakota is offline
Default Putting gas in tanks
Has anyone leaked checked their fuel tanks by actually putting fuel in them?
I'm thinking that the most likely place for the tanks to leak would be the rear of the tank.
So why not put the tank on a table with the leading edge facing up, and put about a gallon of fuel in the tank? That should be enough for 1/2 to an inch of fuel on the bottom.
Has anyone done this? Is there any reason NOT to do this? I just don't trust the balloon test. There's too many places for air to leak out like the fuel caps and the balloon itself.
I would hate to 'think' the test is good, bolt the tanks on, paint the wings, and the find out there is a small leak somewhere!
Thoughts??
Mark Pensenstadler
1962 Piper Cherokee 160
2003 RANS S-10
2011 RANS S-6S
2011 Vans RV-7
2015 Zenith Cruzer
1962 Mooney M20C
2019 KITFOX Super Sport
Old 11-03-2013, 03:49 PM
bhester's Avatar
bhester bhester is offline
Exclamation Check it with air
The leak could be at any rivet. Put the fuel cap on and seal the cap with duct tape to eliminate the cap from the test. Use the drain to put a very small amount of air pressure in the tank. If your using a air tank let the pressure in the tank out until it is below 20 psi you are only going to put a enough air in to inflate the balloon. By using a balloon you can make sure you don't put to much in, if you put too much in the balloon will burst. If there is a leak it is going to deflate pretty quick. The change in the temp will cause the balloon to slowly deflate and inflate over time. Use soapy water and a spray bottle to check around all areas that might leak.
Bobby Hester - Builder/Pilot/A&P
Surfing the web from Hopkinsville, KY
N857BH RV7A XP-O360 - Garmin G3X ADS-B IN/OUT 2020 Compliant
Web site: http://www.newtech.com/bobbyhester/RVSite.htm
Dec. 2019 VAF donator - alot better than any magazine subscription
Old 11-03-2013, 04:24 PM
APACHE 56 APACHE 56 is offline
I did the balloon test and it passed. However, about that time there were a series of posts on the forum regarding tank leaks and the onerous process of fixing them. So I did the six sigma test. I put the wings on a big very well padded bench and filled to capacity with avgas. No leaks.
Another major motivation was the hassle of removing the tanks (should that be necessary) after you have them painted.
Don Stiver
RV8 "Little Pill" N6371S, Merritt Island, Fl.
BPE IO-390, Dual P-mag, MT 3-blade, AFP system
Steen Skybolt: Sold
Old 11-03-2013, 04:35 PM
s10sakota's Avatar
I did the balloon test and sprayed the tank with soapy water. The only leaks I could find were at the balloon itself...
...and the tank drain (which has the bicycle pump fitting in it). Obviously the fitting is going to come out, but I'm wondering if there is any type of sealant I should put on the threads of the actual drain fitting to prevent leaks there?
Mark Pensenstadler
2003 RANS S-10
2011 RANS S-6S
2011 Vans RV-7
2015 Zenith Cruzer
1962 Mooney M20C
Old 11-03-2013, 04:50 PM
bird's Avatar
bird bird is offline
Default Sealant
Yep, permatex # 2 is a good sealant for that.
Bird
Bird
rv8 entire airframe at airport now, painting done, intersection and gear upper and lower fairings done, maybe order engine around first of year or before the next rate increase.
"to fly is a privilege that I am so thankful to God for"
http://www.mykitlog.com/tcb328/
Old 11-03-2013, 05:02 PM
s10sakota's Avatar
Sorry for a dumb add-on question, but when the airplane gets painted, does the fuel drain come out or is it just taped over for paint? If it has to come out again, I won't seal it up now!
Mark Pensenstadler
2003 RANS S-10
2011 RANS S-6S
2011 Vans RV-7
2015 Zenith Cruzer
1962 Mooney M20C
Old 11-03-2013, 05:12 PM
Pat Hatch's Avatar
Pat Hatch Pat Hatch is offline
Thoughts??
Mark, that's exactly what I did. With three airplanes. I put 6 gallons of 100LL in each tank then sat them on the rear baffle for a day or so. Then I sat them on one end for a day, and so on. I also sat them in the cradle with the leading edge down for a day. This is the only reliable method to truly guarantee leak-free tanks, in my opinion. I think air molecules are larger than fuel molecules so in theory you might pass the pressure test and still have a leak with fuel.
Pat Hatch
RV-4 (Gone to RV heaven)
RV-6 (N44PH - Flying)
RV-7 (Sold)
RV-8 (Builder & Avionics Installer)
www.phaviation.com Trim Relay Boards/Flap Actuators
www.pathatch.com/blog (Photography)
Track Me
Old 11-03-2013, 05:23 PM
s10sakota's Avatar
Glad I'm not alone Pat! I'm going to do the exact same thing tomorrow. I just need to get the Permatex-2 to install the fuel drain!
Mark Pensenstadler
2003 RANS S-10
2011 RANS S-6S
2011 Vans RV-7
2015 Zenith Cruzer
1962 Mooney M20C
Old 11-03-2013, 05:24 PM
Pat Hatch's Avatar
Mark, you should not seal the fuel drain now. It will be removed a few times prior to paint; for example, if you test your tanks with fuel and then have to drain it. In any case, just a little Permatex #2 is all you need. You'll want to be able to remove it for maintenance, like if you need to change the O-ring some day.
Pat Hatch
RV-7 (Sold)
Track Me
Old 11-03-2013, 08:08 PM
bhester's Avatar
Thumbs up Fuel lube
I've used Fuel Lube on my drains with no leaks. I also keep a spare drain valve in my tool bag. You will need to replace the small o-ring in the future and having a spare drain vavle in really nice.
