Old 11-03-2013, 02:22 AM
PIN 37 PIN 37 is offline
Default Defeated by the Tip up
Well after many hundreds of hours working on the Tipup, it has defeated me, I give up. I have spent quite a few hundred dollars getting the WD-716 weldment modified and lots of hours fitting, but I cant get it right. It is now so far out of alignment it would have to be replaced. I had the c-702 skin and the f-771 skin almost aligned and made one more cut and weld to get it right on the pilot side and now it is just rubbish. I give up, dont know where I am going to go from here, I have been working steadily for 8 years but have now lost motivation, bummer
Phil
LAME (Aust)
RV7 99% finished
Old 11-03-2013, 04:22 AM
rgmwa rgmwa is offline
Sounds like it's time for a Coopers, Phil, or maybe something from the Barossa. After 8 years, I don't think you'll be giving it away anytime soon. We all have those days.
Cheers
Rob
rgmwa
RV-12LR 912ULS
120346
Old 11-03-2013, 04:23 AM
rbibb's Avatar
rbibb rbibb is offline
Take a step back, work on something else, bum a ride, have a drink and then - finish the thing. Don't let the quest for perfection be the enemy of the "good enough'.
Richard Bibb
RV-4 N144KT
Fredericksburg, VA
KEZF
Old 11-03-2013, 05:26 AM
mick's Avatar
mick mick is offline
Phil
Give me a call, I have done a few tip ups and sliders and maybe able to help you with a couple of ideas. Pity your in SA and I'm in Vic.
Phone 0417 455 244
Mick
Old 11-03-2013, 07:05 AM
Captain_John's Avatar
Relax and have a Bundaberg! I have a bottle on my bench right now.
I think that you are trying too hard.
The tipper is certainly a moving target. You need to roll with it in a Zen-like fashion!
Hang in there and don't let it throw ya!
. CJ
The experiment works!
Old 11-03-2013, 08:16 AM
Jaypratt's Avatar
Jaypratt Jaypratt is offline
Default Tip Up
Phil,
I feel your pain. I have built several tip ups here at RV Central, and never been really happy with how they turn out. My learning curve has been flat. I do know how to fix one though.
Jay Pratt VAF #2
RV Central - Builder Assistance
Paul Revere, Borrowed Horse, & Shooter
Old 11-03-2013, 03:26 PM
s10sakota's Avatar
s10sakota s10sakota is offline
After reading so many horror stories about the tip up (which is what I want) my question is: Why has Vans not been able to make a tip up that fits?
Is the quality just that bad? All airframes should be the same right? So why doesn't the canopy fit?
I don't have my fuse kit yet, but I'm planning on the tip-up but I've heard nothing but horror stories about building it!!
Mark Pensenstadler
1962 Piper Cherokee 160
2003 RANS S-10
2011 RANS S-6S
2011 Vans RV-7
2015 Zenith Cruzer
1962 Mooney M20C
2019 KITFOX Super Sport
Old 11-03-2013, 03:54 PM
bruceh's Avatar
bruceh bruceh is offline
I think that is why the design is so different now on the RV-12 and RV-14.
The tip up canopy is by far the most frustrating experience of the build. Mine took about a year (off and on) and every time it sat a little bit different. Still have some "scoops" on the front. However, it is "good enough" and it will have to be what it is. I don't believe there is a "perfect" tip up.
As others have said - give it a break, then come back to it. Persistence here is what it takes.
Bruce Hill
2020 VAF donator
Old 11-03-2013, 04:10 PM
Brantel's Avatar
Brantel Brantel is offline
A few...a very small few are lucky and somehow they manage to build a tipper without the scoops in the front.
The rest of us fight it as long as we can and then give up and cover up the problem with various techniques hidden by paint.
The bottom line is that the parts don't fit the 7's fuse and Van's either does not care or they are in denial about it....Its one of the few things that make me wish I had built a slider. (they have their own set of issues however)
Forget about trying to get the tipper perfect early in the process. This is false security as it will move all over the place again after you fasten the bubble to it and finish the glass work.
Be careful to not catch the front of the canopy skin on the top front skin as this may cause injury or death to innocent bystanders.....
Brantel (Brian Chesteen),
RV-7/TU, #72823, N159SB
Track N159SB (KK4LIF)
Old 11-03-2013, 04:16 PM
scard's Avatar
scard scard is offline
Hey, speak for yourself . Mine is perfect, as far as I can tell . It is just another art project. So much fun that I'm building another (different) one.
Scott Card
CMW E-Lift
