Old 11-02-2013, 07:42 PM
ron sterba ron sterba is offline
Question Dynon, Manifold pressure hook up
RV9A IO-320. Iam using Vans manifold kit that comes with 18" steel braided hose to hook up to my Dynon manifold pressure sensor module. If I come off of the #3 cylinder port my cable appears way too long. I would like to pass thru the firewall at just below the brake fluid reservoir and the port on the #1 cylinder is perfect length to firewall fitting. Is there a difference in #1 or #3 port readings?
Thanks Guys
Ron in Oregon
Old 11-02-2013, 10:14 PM
Jeff R's Avatar
Jeff R Jeff R is offline
No difference. I used #1 as well for the same reason.
Jeff Rosson
Repeat Offender
RV14 - Working on Empennage/Tail Cone
RV9A - Completed! First flight on July 18, 2012!
Based at Merritt Island, FL (KCOI)
VAF Number: 1170
Star Trek Quote: "Logically, it could work. Also, logically, there are a hundred variables, any one of which could put us in a worse position than we're in now." Mr. Spock in Return to Tomorrow
Old 11-03-2013, 12:24 AM
Thanks Jeff, I installed it after a friend indicated that it makes no difference which one of the four ports. Installed the hose tonight and it came out nice! How did you make the transition from Vans little hose to Dynons bigger port on the module?I see I got some catching up to do. My kit is 91669
Ron in Oregon
