11-01-2013, 10:54 AM
Fuel tank slosh peeling/cracking
Any suggestion on easy fix on tank sealant peeling or cracking
11-01-2013, 10:56 AM
Senior Curmudgeon
Easy is not cheap, cheap is not easy.
Search for "slosh" and read up.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
11-01-2013, 11:04 AM
Wher do I find slosh
11-01-2013, 11:24 AM
Senior Curmudgeon
Slosh is what they used to use for tank sealing, not compatible with the newer fuel formulas.
Click here http://www.vansairforce.com/community/search.php and type in slosh in the search box.
Mike Starkey
VAF 909
Rv-10, N210LM.
11-01-2013, 11:50 AM
I've always heard sloshing is a bad plan as it inevitably comes loose and causing fuel blockage in strainers.
Best long term plan is replace the tanks....
Long-EZ built 1985 -> Sold 2007
RV-9A; N539RV First Flight: 7/2010
RV-8A N468DL 40 hr Flight Test Program
Building Log: www.mykitlog.com/n539rv
APRS Tracking: aprs.fi/n539rv
2017 Paid
11-01-2013, 11:52 AM
Paul at Weep No More
Give Paul at Weep No More a call http://www.weepnomorellc.com
He removed the slosh from my tanks, and resealed them. He did a great job and emailed me pictures along the way.
Jim Lewellyn
N6312V
RV6 - O-320 FP
GRT Sport & GRT AP
11-01-2013, 01:00 PM
There have been accidents (some fatal) as a result of slosh coming loose in tanks. If you have "sealant" peeling and coming loose...I'd send the tanks out for repair, or better yet...just build new ones. No amount of money is worth saving when the engine sputters to a stop. Just my two cents...
Aaron Arvig
RV-9A
Empennage Done
Wings-In Progress
N568AK Reserved
SOLD?but I'll be back
11-01-2013, 01:58 PM
Another option is to get Evans Aviation to build you new tanks.....I might go that route on my -4 if they don't clean up easily. http://www.evansaviationproducts.com
Robert Kramar
Gilbert, Arizona - Vans RV-6A
- Bell 47 D-1 H-13 Sioux Army/Mash Helicopter - Fully Restored and Flying!
- Vans RV-4 (being upgraded to new panel, firewall, weldments and long gear legs)
Yearly VAF dues paid to date.
11-04-2013, 09:19 AM
peeling slosh
I posted the question on slosh peeling for a friend who has a RV6,1992 built,
and on Saturday while doing a preflight we found evidence of peeling after removing a fuel cap and using a penlight, the sad news stared back at us.
I knew that many RVers would reply, and thought it the best way to show
a new RV pilot how much Dougs' website can bring expert advice on any
problem with his airplane.
Thank you all for your response,now all he has to do is choose the way to
solve the problem. I think he will choose to have new tanks built, as
repair of the tanks seems to be as costly as new ones.
Dale F. Field
11-04-2013, 09:34 AM
Senior Curmudgeon
Originally Posted by Dale F. Field
I knew that many RVers would reply, and thought it the best way to show a new RV pilot how much Dougs' website can bring expert advice on any problem with his airplane.
So, has he signed up with VAF yet??
Thank you all for your response,now all he has to do is choose the way to solve the problem. I think he will choose to have new tanks built, as repair of the tanks seems to be as costly as new ones.
Dale F. Field
He can repair them himself, and save a lot of $$$. Big advantage of repair vs new is the paint job will still match.
A good contact to discuss the repair process would be Rosie. Also, Dan Horton has some good info on opening and re-closing fuel tanks, not sure if Dan has done the slosh removal thing however.
http://www.vansairforce.com/community/member.php?u=9
http://www.vansairforce.com/community/member.php?u=2320
Mike Starkey
VAF 909
Rv-10, N210LM.
