12-14-2013, 05:29 PM
assembly
Not unlike our getting ready for a run at riviting a surface, all the parts get set our on a bench ready to install.
Kahuna
6A, S8 ,
Gold Hill, NC25
12-14-2013, 05:33 PM
Pistons
All pistons are the same weight.
Using piston pin & plug assemblies.. plugs are pressed into the pins eliminates plug wobble that sometimes fails on stock lycoming floating plugs
Kahuna
6A, S8 ,
Gold Hill, NC25
12-14-2013, 05:37 PM
Gear terrain
Kahuna
6A, S8 ,
Gold Hill, NC25
12-14-2013, 05:40 PM
Getting close
It wont be long now! Still have to button her up, get some cool paint on, and crate.
Kahuna
6A, S8 ,
Gold Hill, NC25
12-14-2013, 05:50 PM
Great thread, great pics .... thanx much !
Terry Ruprecht
RV-9A Tip-up; IO-320 D2A
S. James cowl/plenum
(Dues paid thru Nov '18)
12-14-2013, 06:46 PM
Senior Curmudgeon
Originally Posted by Kahuna
The crank is also Dynamically Spin Balanced. Counterweights Matched Weights.
It would be interesting to see how they deal with the movable weights for the spin balance.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
12-15-2013, 09:06 AM
Did you plug the oil channel for the unused idle gear? was thinking on the same thing on my 360...
Dennis Isaksson
G?llivare, Sweden
Grew up with an RV-4, SE-XIO
Now: RV-8, Showplanes Fastback. #83218 Under construction, SE-XXO
Engine and avionic installation in progress
12-15-2013, 09:08 AM
Yes I sure did. An aluminum plug with an o-ring seal.
Kahuna
6A, S8 ,
Gold Hill, NC25
12-15-2013, 09:20 AM
Why is the yellow type around the lower part of the cylinders only?
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
12-15-2013, 09:25 AM
This reduces, if not eliminates, those pesky leaks at the thru bolts and reduces the fretting of the cases. At assembly, the case halves get pulled together and the fit is at the dowels. An important item for the next overhauler to know! Since the case will not just fall apart when you remove the thru bolts.
Actually this is an incorrect statement. The reason for the dowels are to bring those holes back up to size, not to prevent leaks. Actually adding a second path around the bushing increases the likelihood of a leak since now there are two paths for the oil to travel. They don't do that to make them stop leaking there. The o-ring counterbore mod is done to prevent leaks.
On the 540 there is an oversize thru bolt available so its just as good to ream the holes to .002 undersize for the larger thru bolt, and then you can counterbore for the o-ring.
So unless one could not ream to fit to size for an oversize thrubolt, I would not do this mod.
Bob Japundza CFI A&PIA
N678X F1 Rocket, under const.
N8155F C150 flying
Not a thing I own is stock.
