Quickbuild Tip Up Build Question
How have most people installed the 3 front rivets on the top fuse skin just behind the cockpit. Did you remove the cockpit cross bar and associated angles, rivet skins, and then reassemble or just use pull rivets? If pull rivets, what part number.
Alan
