Old 10-30-2013, 01:59 PM
airguy's Avatar
airguy airguy is offline
Default Heat muffs and stainless steel wool
I've seen several builders post about packing their heat muffs with stainless steel wool to enhance the heat transfer, and I was planning on doing just that but now I can't find any STAINLESS steel wool locally. Standard steel, yes, but that will oxidize and fall out rapidly, not what I want to see happen. I found some copper wool, but no stainless. Anybody have a good source?
Old 10-30-2013, 02:07 PM
qtrmiledan qtrmiledan is offline
Default SS Wool
Greg- McMaster Carr has it.
Danny B
Baker,La.
RV9A #91137 Flying!!
Old 10-30-2013, 02:15 PM
pa38112 pa38112 is offline
I bought some through amazon. I remove it in the summer months to prevent over heating the exhaust.
http://aprs.fi/N153MC
2004 RV6A Flying
2002 RV6A Flying
1978 PA38-112
Old 10-30-2013, 02:44 PM
Andy Hill's Avatar
Andy Hill Andy Hill is offline
Or similar
Andy & Ellie Hill
RV-8 G-HILZ
RV-3B G-HILI very slow build
RV8tors
Old 10-30-2013, 02:57 PM
Noah's Avatar
Noah Noah is offline
I found bronze wool locally.
Highest Regards,
Noah F, RV-7A
All men dream, but not equally. Those who dream by night in the dusty recesses of their minds wake in the day to find that it was vanity: but the dreamers of the day are dangerous men? for they may act their dream with open eyes, to make it possible. -T.E. Lawrence
Old 10-30-2013, 03:15 PM
airguy's Avatar
Order placed - thanks!
Old 10-30-2013, 04:15 PM
Capflyer's Avatar
Capflyer Capflyer is offline
Just go to any grocery store and pick up the stainless steel pot scrubbers....it is all the same stuff.
Mike
JAMES AIRCRAFT.com
Flying - RV8 Hot Rod "Drone Killer"
Flying - RV8 "Look'n Good"
RV4 - FAST & FUN! Rebuilt, Flown, Sold
RV-7A Built, Flown, Sold
Old 10-31-2013, 09:57 AM
airguy's Avatar
That was the trouble I was running into - they don't sell them locally apparently - lots of standard steel wool and even some copper wool, but everything else is nylon scrubbers now. People want cheap and disposable stuff.
Old 11-01-2013, 04:11 AM
Capflyer's Avatar
Another suggestion would be to head to the local restaurant supply house or perhaps one of the restaurants you go to will sell a few to you. Every restaurant that scrubs pots uses these (asuming your state doesn't have restrictions against them, some do). They cost the restaurant about $1 apeice unless they have a naughty distributor salesman and sleeping buyer. The commercial ones are also larger and more robust than household versions.
Mike
JAMES AIRCRAFT.com
Old 11-01-2013, 08:38 AM
rvbuilder2002's Avatar
Just to clarify... Do not put regular steel wool pads (or any other similar metal pad) in your heat muff(s). It will be far to restrictive of airflow and will likely over heat the muff. The product to use (as already mentioned) is Stainless Steel pot scrubber pads. They are far less restrictive, but still add huge amount of extra heat conduction surface area.
Scott McDaniels
Hubbard, Oregon
