Old 10-29-2013, 01:20 PM
Eddie Eddie is offline
Default Brace position during emergency landing
Hi all
Im a new RVator and was wondering what the best brace position during a forced landing would be... With the nose wheel I will have a good chance of flipping over?
Normally one would bend forward with your bead between your legs... But with the stick right there and a pretty strong roll bar, should you not keep your head back?
That's for the passenger, obviously the pilot needs to keep flying as far as possible...
Thanks guys
Eddie
Remove (ego) before flight
RV-10, ZU-RVI
Old 10-29-2013, 01:52 PM
DGlaeser DGlaeser is offline
Default Upright - belts tight
Putting your head down in an RV is not a good idea IMHO, because it guarantees a head impact. I suggest tighten your belts and if you have anything soft (jacket, pillow, ...) hold it against your face.
There is a good chance of flipping regardless of nose or tail wheel, if the surface is not nice and smooth.
Dennis Glaeser CFII
Rochester Hills, MI
RV-7A - Eggenfellner H6, GRT Sport ES, EIS4000, 300XL, SL30, TT Gemini, PMA6000, AK950L, GT320,
uAvionixEcho ADSB in/out with GRT Safe Fly GPS
Old 10-29-2013, 02:11 PM
RVDan RVDan is offline
I agree with Dennis- you can't hold your head/body against crash G forces. Tighten seatbelt and especially shoulder harness and pad their face.
This is also the time to be thankful for a crotch (anti-submarine) belt if you have one.
Dan Morris
Frederick, MD
PA28-140
Hph 304CZ
RV6 built and sold
N199EC RV6A flying
Learn the facts. "Democracy dies in darkness"
Old 10-29-2013, 03:24 PM
N941WR's Avatar
N941WR N941WR is offline
The proper sequence for tighten your harness is crotch strap first, then the lap belts, and the shoulder belts last.
The idea is to keep the lap belt low across your hips and not in your gut.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 10-29-2013, 03:33 PM
walkman's Avatar
walkman walkman is offline
wrt to sliders. One of the OWTs or myths or suggestions going around the Grumman community for a while, was to open the canopy and stick a shoe to prevent it jamming closed or the latch closing.
What does the peanut gallery think about that suggestion for slider RVs?
RV-8 IO-360 (Bought)
RV-6 O-360 C/S (Sold)
Walkman aka Flame Out
Old 10-29-2013, 03:46 PM
Neal@F14's Avatar
Neal@F14 Neal@F14 is offline
I think if a slider canopy is gonna jam, it'll still jam even if it's partially opened with a shoe wedged in there when the sudden deceleration at the end of the "landing" slams it shut. That's why I've started carrying one of these as an emergency egress tool.
Neal Howard
Airplaneless once again...
Old 10-29-2013, 04:38 PM
grubbat's Avatar
grubbat grubbat is offline
Default Arm
Put your arm (the one less used) in front of your head so you will break it or cut it off instead of your head. Blunt trauma to the head is a common occurrence in a wreck and your arm may provide a cushion. Of course, if you survive the impact, you may have a tough time with a severed or broke arm especially if there is a fire.
RV's need more padding on the dash just for this reason. My -6 has a thin piece of metal there. I wished I had some dash padding like you would find in vehicles.
Craig
RV-3 Sold
RV-4 Sold
RV-6a Sold
RV-9 IO-360 CS, Built and Flying
Aerostar 600A, Family Hotrod
