Old 10-29-2013, 06:49 AM
vasrv7a vasrv7a is offline
Default Owner pilot maintenance of an E-AB airplane without repairman's certificate?
Can someone please point to the source that will explain what maintenance an owner pilot of an E-AB airplane can perform who does not have the repairman's certificate for that airplane. I need to replace the electric fuel pump (Facet 40108) on my RV and would like to know if I am required to have an A&P do the work, or am I permitted to do it myself.
Thanx.
Victor
Old 10-29-2013, 06:56 AM
Sid Lambert Sid Lambert is offline
You can do anything that is comfortable and safe yourself. If you are not mechanically inclined it may be best to save it for someone who is or at least consult them.
The only thing you can't do legally is the condition inspection.
If you want to replace the engine with a rubber band powered unit you are free to do so with some paperwork of course.
Sid Lambert
RV-7 Sold
RV-4 - Flying - O-320 Fixed Pitch - Red over Yellow
Old 10-29-2013, 07:09 AM
Mel's Avatar
Mel Mel is offline
As far as pointing to a regulation. It's actually a "lack" of regulation.
Part 43 is the reg that states who CAN perform maintenance on aircraft and part 43 does not apply to experimental aircraft except where referenced in the operating limitations in regards to the condition inspection.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 10-29-2013, 10:09 AM
az_gila's Avatar
az_gila az_gila is offline
Question
Mel,
Even though Part 43 doe not fully apply, I presume that the recording requirements of 91.417 are still applicable.
Is that correct?
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 10-29-2013, 10:54 AM
Mel's Avatar
Mel Mel is offline
Originally Posted by az_gila View Post
Mel,
Is that correct?
That is correct!
Old 10-29-2013, 12:16 PM
So, if I correctly understand the replies... I am permitted to change the electric fuel pump myself if I so choose. However I am still required to record the activity in the aircraft log book just as I do when changing the oil for instance...?
Thanx everyone...
Victor
Old 10-29-2013, 12:54 PM
Sam Buchanan's Avatar
been here awhile
Thanx everyone...
Victor
There are no regulations per FARs to make any entries in the logs except for completion of the annual condition inspection.
I know this is startling for someone coming out of the certificated universe--welcome to Experimental Aviation!
Sam Buchanan
RV-6
Fokker D.VII replica
Old 10-29-2013, 01:11 PM
az_gila's Avatar
Not if you believe that 91.417 applies to Experimentals -
http://www.ecfr.gov/cgi-bin/text-idx...5.7.10&idno=14
And the FAA does not use the word "logs" or "log book" - they refer to them as "maintenance records" and can be in any form - even on toilet paper as long as you keep them as required...
(1) Records of the maintenance, preventive maintenance, and alteration and records of the 100-hour, annual, progressive, and other required or approved inspections, as appropriate, for each aircraft (including the airframe) and each engine, propeller, rotor, and appliance of an aircraft. The records must include—
Gil Alexander
Old 10-29-2013, 02:05 PM
RVDan RVDan is offline
Curious if part 91 rules like 91.407 and 91.417 which are applicable to our experimental aircraft (91.1) and reference back part 43, invokes those limited sections of part 43 by reference?
Seems to me like the language would do that. Therefore, aircraft record entries would be required for the listed types of maintenance??
Anybody oficially know if this is true?
Dan Morris
Frederick, MD
PA28-140
Hph 304CZ
RV6 built and sold
N199EC RV6A flying
Learn the facts. "Democracy dies in darkness"
Old 10-29-2013, 02:45 PM
Wow... Thanx for all the great info!!!
Much appreciated.
Victor
