Old 10-28-2013, 07:11 PM
Dean Pichon Dean Pichon is offline
Default Looking for a source for (tailwheel) bearings...
My tail wheel bearings need to be replaced. The are flanged and sealed and measure .75"ID x 1.375"OD. So far, I have tried Flyboy Accessories, McMaster, Grainger, PIC, and Berg. Any recommendations would be appreciated.
[IMG][/IMG]
Old 10-28-2013, 07:50 PM
bird's Avatar
bird bird is offline
Do a search under "timken bearings" , you will need to measure the dimensions.
Bird
Bird
rv8 entire airframe at airport now, painting done, intersection and gear upper and lower fairings done, maybe order engine around first of year or before the next rate increase.
"to fly is a privilege that I am so thankful to God for"
http://www.mykitlog.com/tcb328/
Old 10-29-2013, 12:22 AM
tfarrell839 tfarrell839 is offline
Default Applied industrial technologies
Applied Industrial: Many cities have a distributor. Our local guy likes to hear that you are putting it in an wheelbarrow or something, we don't mention airplanes.
Old 10-29-2013, 03:26 PM
RV8Squaz's Avatar
RV8Squaz RV8Squaz is offline
Vans sells them.
Jerry Esquenazi
RV-8 N84JE
Old 10-29-2013, 05:25 PM
Thanks for the lead. I found some at Applied Industrial. Funny you said "wheelbarrow". I brought the bearings to work and showed them to a colleague who specs bearings for many of our systems and said "These look like they come from a wheelbarrow".
Thanks again.
