The bigger issue is the length of the nose main bearing. Gyroscopic loads on the nose bearing, and the bending of the crank during acro with heavy props spinning at high RPM are the conditions to worry about.
If using a counterweighted crank then there are other, more complex issues at hand.
'83 LongEZ - N888EZ 3,671 hours
'89 LimoEZ - N26EZ 686 hours (sold)
A couple of Glasairs and a Lancair 320...
Next: a RV14 need something to build
