Old 10-27-2013, 06:16 PM
Veetail88's Avatar
Veetail88 Veetail88 is offline
Default Oil leak above the oil pan/intake plenum
I have an oil leak. It originates between the crank case halves just above the oil pan/intake plenum. Will torqueing these bolts a bit more seal this or is it a bigger problem?
Jesse Bentley
N229Z - RV-8 - Flying - Livin' the dream!
Old 10-27-2013, 06:29 PM
Russ McCutcheon's Avatar
Russ McCutcheon Russ McCutcheon is offline
It probably won?t help but it?s also probably not a problem, I have heard some say there engines don?t leak; personally I have never seen a dry Lycoming with more than a hundred hours. If it?s pouring out then ok maybe a problem, if it just has drips hanging off the bottom and everything underneath has a shine of oil on it that?s normal.
Russ McCutcheon
@rv4welder on Facebook
russmccutcheon@gmail.com
We build many of your RV weldments.
Old 10-27-2013, 06:37 PM
My Leakoming has several spots like yours. It doesn't consume extra oil however. I clean it once in a while with cloth using avgas. You will see these oily spots in some weird places on your engine.
Old 10-27-2013, 07:24 PM
Bavafa Bavafa is offline
My Leakoming engine.
I have one of those engines as well.
Mehrdad
N825SM RV7A - IO360M1B - SOLD
N825MS RV14A - IO390 - SOLD
N258SM RV14A - IO390EXP119 - in progress
Dues paid
Old 10-27-2013, 07:29 PM
LifeofReiley's Avatar
LifeofReiley LifeofReiley is offline
Sorry Jesse, that is not a leak. Just a confirmation of a healthy aircraft engine.
Reiley
Retired N622DR - Serial #V7A1467
VAF# 671
Repeat Offender / Race 007
Friend of the RV-1
Old 10-28-2013, 06:58 AM
rocketbob's Avatar
Unfortunately Lycoming and many others still use 60+ year old techniques (silk string) to seal cases halves and they will leak sometimes in short order. In this case it appears the sump gasket was put on dry (another way to ask for leaks) and because of that there is nothing effectively sealing that corner. You might try removing the sump and replacing the gasket with it rubbed on both sides with Titeseal.
And yes they can be made to not leak, I was just looking over the weekend at an A65 Continental I built several years ago that operates several hundred hours a year and it only had some minor seepage around the cylinder bases.
Bob Japundza CFI A&PIA
N678X F1 Rocket, under const.
N8155F C150 flying
Not a thing I own is stock.
Old 10-28-2013, 07:39 AM
csmith3603 csmith3603 is offline
Default Oil seal
Dang, that Rocketbob always has the best solutions,,, Go Army.
Old 10-28-2013, 07:43 AM
Walt's Avatar
Walt Walt is online now
Should only take about "10 minutes" to pull the sump and reseal
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
RV7A built 2004, 2000+ hrs, New Titan IO-370, Bendix Mags
Old 10-28-2013, 08:16 AM
RV8iator's Avatar
RV8iator RV8iator is offline
Default Come on Walt
I know this is a tongue in cheek remark..
It really takes about 30
Jerry "Widget" Morris
RV 8, N8JL, 3,100+ hours on my 8.
VAF #818
Saint Simons Island, GA. KSSI
PIF 2007 - 2022
I just wish I could afford to live the way I do
Old 10-28-2013, 08:50 AM
mannanj's Avatar
mannanj mannanj is offline
Default Cheek
And that's just to get the cowl off!
LAUS DEO
Mannan J.Thomason, MSGT. USAF (RET)
VAF788
"Bucket List" checkoff in progress!
