Go Back   VAF Forums > Avionics / Interiors / Fiberglass > GPS
Old 10-25-2013, 11:55 PM
N57GK N57GK is offline
Default IFR Legal? KLN 90B GPS without CDI and Annunciator?
Hi All, this is my first post...
I purchased an RV-8 in March and with winter approaching quickly in New England, I decided to try to make it IFR legal. So I designed a new panel (using almost all the existing equipment and only adding an IFR GPS and some customization) and built it up. I left space for, but I haven't gotten an indicator for the GPS (KLN 90B) and was trying to figure out if it is needed...
So three questions:
1. Do I need an indicator to be IFR legal with an up-to-date GPS database and all the other requirements being met?
2. Do I need external indicators to be legal?
3. Anyone know where I can get a KI 202, 206 or other recommended CDI?
Thanks in advance! -Kyle
BTW, how to you insert photos? It asks me for a website when attempting to do so...
Old 10-26-2013, 12:23 AM
RV6_flyer's Avatar
So three questions:
You need all the equipment that is required in a Certificated Airplane Installation to be legal.
So...
1. Yes
2. Yes
3. Try SteinAir.
Gary A. Sobek
NC25 RV-6
Flying
3,400+ hours
Where is N157GS
Building RV-8 S/N: 80012
Old 10-26-2013, 02:37 AM
turbo's Avatar
turbo turbo is offline
There was an article in the sport aviation mag about ifr equipment. I'll try and get the specific issue for you. A good auto pilot and back up systems are a must. welcome to the VAF site. See you next summer in vt.
TURBO YES =VAF= Payed Jan2019
Ed D'Arcy
addicted pickle ball player
Old 10-26-2013, 05:06 AM
terrykohler terrykohler is offline
Default If You Have To Ask...
Kyle:
As a newly minted instrument pilot (or a long time pilot with limited instrument experience), you should probably be thinking not only minimum equipment, but also maximum situational awareness. Also, once you have the equipment, I'd suggest some additional training to help determine where your comfort level is with it.
Many instrument pilots will say ,"I won't fly unless I have personal minimums of such and such". Truth is, when you're in "the system", you'd better be able to really fly on the Gage's and shoot approaches to minimums. In addition, if you can't do either of these without anxiety, you really shouldn't be flying IFR.
Finally, Ed's suggestion above for an AP is a good one, especially in a short wing RV- and he's got plenty of experience to back up his suggestions.
Welcome to the RV nation.
Terry, CFI
RV9A N323TP
Old 10-26-2013, 05:31 AM
pierre smith's Avatar
Default Not necessarily.
Kyle, you didn't say whether you have a glass panel or steam gauges.
I have a glass Dynon 100 and it's HSI is legal. No outside indicator is necessary and I've done IFR demonstration to satisfy my CFII.
IIRC, all the new glass has an HSI with glideslope capabilities.
Best,
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
Old 10-26-2013, 05:55 AM
rv7boy's Avatar
rv7boy rv7boy is offline
Forum Peruser
I purchased an RV-8 in March and with winter approaching quickly in New England, I decided to try to make it IFR legal....
So three questions:
Answer to your fourth question can be found by clicking the link on the first page of these forums, upper left corner, fourth line down, "Insert Pics."
Don Hull
RV-7 Wings
KDCU Pryor Field
Pilots'n Paws Pilot
Old 10-26-2013, 05:59 AM
Arlen's Avatar
Arlen Arlen is offline
FAR 91.205 lists all the requirements:
http://rgl.faa.gov/Regulatory_and_Gu...tLookup/91.205
Arlen
Donation to VAF 10.29.18
RV-6, February '14, SOLD December '15
Old 10-26-2013, 06:11 AM
rzbill's Avatar
rzbill rzbill is offline
This question can be answered by reading the installation manual rather than speculating on a forum.
The install manual is the ruling document for a particular piece of equipment that has been IFR approved by the FAA.
Section 1.8 spells it out quite plainly.
Bill Pendergrass
ME/AE '82
Old 10-26-2013, 07:53 AM
Dan B Dan B is offline
In addition to the install manual, AC 20-138 provides an FAA acceptable installation process. Chapter 11, among other areas, should be helpful.
http://www.faa.gov/documentlibrary/m...%2020-138c.pdf
Dan Burdette
Skyview, ADS-B, Garmin 420W, TT Gemini AP
RV-9A, IO-320, E-Mag
Guthrie-Edmond Rgnl, OK (KGOK)
________
Old 10-26-2013, 09:09 AM
rocketbob's Avatar
I have a KLN-89B and also a KLN-94. Neither require an OBS and its spelled out in the installation manuals although it states that the installation certifying agency may require an OBS for approach approval. So if you're ok with the additional button pushing that is required to get to the OBS screen then you should be ok without one. Its easy to roll your own external annunciators and switches.
"Being legal" is a particularly gray area when it comes to IFR GPS installations in experimentals. Since the FAA doesn't approve installations its up to you to be compliant.
Bob Japundza CFI A&PIA
N678X F1 Rocket, under const.
N8155F C150 flying
Not a thing I own is stock.
