Old 10-25-2013, 04:06 PM
Bill_In_Diamondhead Bill_In_Diamondhead is offline
Default Rudder Pedal Install
Concerning my Rudder Pedal Blocks, I have two issues. First my AN3-22A bolts are bottoming out on the nutplate. The bolt is too long by 1/4". I might just take the blame for it is possible that when I separated the F-1235A Rudder Pedal Blocks, I may have removed too much material separating the two halves. This is easy fix for I will simply order (6) AN3-20 bolts.
My Second issue is how snug should the blocks hug the Rudder Pedal Shaft. If I place the Blocks on the Rudder Pedal Shaft to check the gap between both blocks, I can place (2) AN-960 washers in the gap between the top and bottom block and I will have a small amount of slack, but this will "Clamp" the block on the shaft very tightly, however if I place (2) AN-960 and (1) AN-960L between the Block halves there will be a little slack in the Shaft/Block before I torque bolt in place.
Should I just use (3) AN-960 and ensure that I do not bind the Rudder Pedals?
Bill
RV-12 #120648
Old 10-25-2013, 08:42 PM
Mich48041 Mich48041 is online now
If you removed too much material when cutting the blocks in half, then the correct fix is to order new blocks, not new bolts. I used a hacksaw to cut the blocks. The plans call for a maximum of 1/16" saw kerf. The sides of a hacksaw blade can be ground down to reduce the rake of the teeth.
A narrower saw kerf will solve both problems.
Joe Gores
Old 10-25-2013, 08:47 PM
RFSchaller RFSchaller is offline
Don't over-think it. Bolt too long? - use shorter bolt. Rudders need to move smoothly, but not too loose.
Old 10-26-2013, 05:48 AM
joedallas's Avatar
joedallas joedallas is offline
Default Do not use a shorter bolt
[quote=Mich48041;819860]If you removed too much material when cutting the blocks in half, then the correct fix is to order new blocks, not new bolts. I used a hacksaw to cut the blocks. The plans call for a maximum of 1/16" saw kerf. The sides of a hacksaw blade can be ground down to reduce the rake of the teeth.
Joe Gores
/QUOTE]
Joe
If the saw cut is .0625 as required by vans and the 6 AN960-10 washers fill the gaps, then tell my why if the saw cut is .125 ( 1/8' ) why can't you use a washer that is .125.
In my opinion the washer is to replace the material removed
Joe Dallas
Joe Dallas
Kit-#12400
www.joesrv12.com
www.EAA1298.com
Old 10-26-2013, 06:07 AM
D&M Dan D&M Dan is offline
I cut as per Van's instructions and had no problems.
Not to take the thread off topic, but I have finished my wire harness above the pedals, but have left them down. I am saving for and do not have my engine package. Can I install the pedal assembly permanently now or should I wait? Not sure if anything more will need to be rooted above the pedals.
Dan
RV12 Flying
Home Field KSDC
Paid 2019
Old 10-26-2013, 08:23 AM
After sleeping on it, I realize that I was wrong about ordering new blocks. Joe Dallas is right.
Joe Gores
