Old 10-24-2013, 04:04 PM
alpinelakespilot2000 alpinelakespilot2000 is offline
Default blue/fuel stain on carb - normal?
During my last oil change I noticed a bit of blue staining around the nut on the bottom of the carb (I'm not sure what it's called). I think it's probably been gradual enough that I just haven't noticed it before, and it doesn't seem to be much of a weep or leak, but what might cause it and what should I do, if anything, to address it?
Thanks.
Steve M.
Ellensburg WA
RV-9 Flying, 0-320, Catto
Donation reminder: Jan. 2021
Old 10-24-2013, 06:44 PM
crabandy crabandy is offline
I'm not a carb expert, but on my Marvel Schebler MA4-5 I have a similar looking copper crush/lock washer that is probably seeping.
RV 7 400 hours and counting
19 donation done
Old 10-24-2013, 06:59 PM
Couple hundred hours ago I noticed this
Cleaned thoroughly and watched closely. Nothing since then.
Old 10-25-2013, 06:30 PM
Thanks guys. I'll keep my eye on it and keep looking for answers.
Steve M.
Ellensburg WA
Old 10-26-2013, 02:52 AM
turbo's Avatar
turbo turbo is offline
Clean it up, snug it down and keep an eye on it. report back next month.
TURBO YES =VAF= Payed Jan2019
Ed D'Arcy
addicted pickle ball player
Old 10-26-2013, 02:14 PM
Thanks Ed. What do I snug down? The outer brass part or the inner silver hex-head screw? Do I need to keep one in the same position while tightening the other down?
Steve M.
Ellensburg WA
Old 10-27-2013, 08:45 AM
turbo's Avatar
clean it off first so you can keep track of the leak. put a wrench on the brass nut and see if it is a bit loose. check with your mechanic if this doent help.
Ed D'Arcy
Old 10-27-2013, 10:57 AM
az_gila's Avatar
az_gila az_gila is offline
Smile
It is probably not a good idea to try and tighten any nuts that are safetied with a bent tab safety washer...
The correct fix would be to remove, replace the tabbed washer, retorque and rebend the tab.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 10-27-2013, 05:25 PM
goatflieg's Avatar
goatflieg goatflieg is offline
This is just a guess... but could the blue stains be a side effect of combining dissimilar metals and aviation fuel?
Old 10-27-2013, 05:55 PM
aerhed aerhed is offline
No, its just blue dye getting thicker as fuel vaps off leaving the dye. Common. Also common are small seeps like this with copper gaskets. Turbo hit it already. Crunch that brass into that copper a microturn and snug the tab flush again. Spritz it clean with a little electronic cleaner and check later. Done.
Actual repeat offender.
