I used a puller
I purchased a small, 2-leg puller from a local auto parts store, and it worked nicely.
The puller left a very small depression in the outboard end of the non-impulse mag shaft which shouldn't be an issue; the impulse mag shaft, interestingly, already had a machined depression.
I don't think you'll be able to remove the gear with any amount of reasonable tapping.
______
VAF dues paid though exempt
RV-9A sold (I miss that bird!)
RV10 sold (miss that one too!)
RV-14A build underway
