I built a fiberglass and resin base about 3/8 thick on the back of the rudder bottom fiberglass part. I'm planning on attaching the light by screwing directly into the fiberglass resin. There is no way to get a nut on the screw.
Would you use a sheet metal screw? Or would you drill and tap for a number 8 screw?
I've done some tests and in 3/8 inch resin it holds either screw very securely. I can't strip the threads in the resin.
Image of the mount and test piece below.
I will use a lock washer between the head of the screw and the light mounting ring.
Michael-
