Go Back   VAF Forums > RV Firewall Forward Section > Propellers
Old 10-22-2013, 01:44 PM
rvator51's Avatar
rvator51 rvator51 is offline
Default prop governor steel line versus hose
Does anyone know the correct length to replace a steel prop governor line with the new Teflon hose for a Lycoming O-360-A1A?
The Lycoming SI 1435 shows 4 lengths:
LW-12799-6S-360 36"
LW-12799-6S-380 38"
LW-12799-6S-400 40"
LW-12799-6S-420 42"
Regards,
Thomas Velvick
Goodyear, AZ (KGYR)
2020 Donation sent.
N53KT RV-6a finished 2018, Flying
N7053L RV-4 Wife's RV
N56KT RV-4 Finishing
Old 10-22-2013, 06:54 PM
Walt's Avatar
Walt Walt is offline
I had Tom (TSflightlines) make me a 36" and it was a tad to long but worked.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 10-22-2013, 11:06 PM
PCHunt PCHunt is offline
Just curious why you would replace an existing steel line with a flex line?
I had a flex line, and when I put a new light-weight C/S prop on the plane, the new prop had a small surge. (The old heavier metal prop never surged.)
Got some (bad) advice that the flex line might be causing the issue, at great expense of time, effort and $$$$, I replaced the flex line with a SS line.
No change to the surge issue.
The fix was a new prop governor.
Pete Hunt, [San Diego] VAF #1069
RV-6, RV-6A, T-6G
ATP, CFII, A&P
2020 Donation+, Gladly Sent
Old 10-23-2013, 12:11 AM
rvator51's Avatar
I need to add the line to my engine and the flexible line is approx $120 versus $300 for the steel line from what I can find.
Regards,
Thomas Velvick
Goodyear, AZ (KGYR)
2020 Donation sent.
Old 10-23-2013, 12:30 AM
PM Sent to you.
RV-6, RV-6A, T-6G
ATP, CFII, A&P
Old 10-23-2013, 05:15 AM
Brantel's Avatar
Brantel Brantel is offline
I think mine was 40" but I am not sure. I went over the engine instead of the traditional path and it is working great!
Brantel (Brian Chesteen),
RV-7/TU, #72823, N159SB
Track N159SB (KK4LIF)
Old 10-23-2013, 07:00 AM
Toobuilder's Avatar
If you can't find one used for $50 bucks, then they are easy to make from about $20 worth of tube and fittings from Spruce.
Michael Robinson
______________
Harmon Rocket II -SDS EFI
RV-8 - SDS CPI
1940 Taylorcraft BL-65
1984 L39C
Old 10-23-2013, 09:23 AM
cajunwings cajunwings is offline
Default Oil Line
Email sent.
