Old 10-21-2013, 08:58 AM
nekit nekit is offline
Default Cold Air Intake/Sump for O-320
Has anyone modified a cold air sump system for a O-320?
From what I can tell Superior and ECI systems are just O-360.
Are the sumps the same and just custom outer intake tubes need made?
Old 10-21-2013, 10:39 AM
EagleEngines EagleEngines is offline
If my information is correct, the only thing you need to use the sumps are different intake tubes, which Superior or ECI will have pn's for.
Matt Brockman
Eagle Engines
530-221-4470
Old 10-21-2013, 01:48 PM
AX-O's Avatar
AX-O AX-O is offline
I did it on my 0-320 B2B. Same sump as 360 but different intake tubes. You will also have to change your oil pick up depending on what system you had before and cut the dip stick. Another gotcha is that a regular exhaust won't work. You will have to specify that you have a cold air sump from XYZ manufacture.
Axel
RV-4 fastback thread and Pics
VAF 2020 paid VAF 704
Old 10-21-2013, 02:57 PM
sbalmos's Avatar
sbalmos sbalmos is offline
I started thinking about doing a cold air sump also on my IO-320. Embarassingly, I have to crack off the sump from my engine anyway - dropped a darn nut down in there while putting on a mag hole cover plate, and my magnetic fishing pole can't snag it.
The only thing I have to wonder is how much performance / fuel efficiency gain do you really get, especially when used on top of an all-EI ignition/injection system like EFII? Would it really be worth my time and money to bolt on a cold induction system if the majority of my performance / efficiency gains are from the EFII system?
Scott Balmos - RV-9A N112SB
Cincinnati, OH, KHAO
Old 10-21-2013, 03:21 PM
AX-O's Avatar
Is up to you to decide, but remember nothing is ?free?. Be prepared for higher oil temps because the incoming air is not cooling the oil. My bud did this change after having over 500 hour with the standard oil sump configuration. He is now seeing 15-18 deg higher for oil temps in all flight regimes.
By the way, I also did the same thing with my hardware.
Axel
Old 10-21-2013, 03:46 PM
mahlon_r mahlon_r is offline
We normally saw about 5-7 HP increase from the same engine updraft vs. Horizontal draft, in the test cell. In addition, the 360 with the forward facing sump and 9:1 pistons pretty much put out 192-193 HP at full power with standard mag ignition and EI that held the timing to 25 BTDC for TO. I would assume, you would see similar gains on the 320 from the stock 160HP configuration.
Good Luck,
Mahlon
"The opinions and information provided in this and all of my posts are hopefully helpful to you. Please use the information provided responsibly and at your own risk."
Old 10-22-2013, 09:50 AM
659JR 659JR is offline
Default pipes
I have two sets of stainless pipes to fit the 320 with the Lycoming sump or I have a 320 superior sump kit as well I can make a deal on. You may have to have custom exhaust made if you go that either way.
Jesse
Old 10-22-2013, 09:04 PM
glenn654 glenn654 is offline
I have an ECI Cold Induction kit I would like to sell, New In Box. For -360 but I think it should work for a -320.
I bought a partially complete -7 which already a cold air induction sys installed.
Asking $ 1600.00
Glenn Wilkinson
_____________________________________________
RV-4 Sold
N654RV @ MLJ
RV-7 Coming Soon
N987RV Reserved
2015 Donation Gladly Paid
"Maintain Thy Airspeed, Lest the Earth Arise and Smite Thee"
