Go Back   VAF Forums > Model Specific > RV-9/9A
Old 10-21-2013, 05:46 AM
RVdreamin RVdreamin is offline
Default Fluting the HS ribs
Guys...still rookie questions I know. Deburred all the HS-904/905 HS ribs and the next step is to flute. The nose ribs on the HS really have no place to apply the fluting pliers because of the notches in the rib flanges and the skin holes. I easily bent one straight because the notches allow an easy 'stress' location to straighten the ribs. The main HS ribs also have notches, but there is room for the fluting pliers. So the question is....Can I manually bend the HS main and nose ribs straight or should I use the fluting pliers? If I should use the fluting pliers, how can I flute the nose ribs on the HS? Thanks for the help..
Jimmy Black
RV-9A
Started Finished 10/16/14
Wings Finished 4/9/16
Fuselage working electrical
Finishing Kit received 9/11/19
HWY
VAF paid 2019
Old 10-21-2013, 06:18 AM
mikehoover's Avatar
mikehoover mikehoover is offline
Here's a picture of how I fluted the front of the nose ribs:
http://www.aclog.com/rv-9a/images/Em...p/DCP_1176.JPG
Here's another showing flutes between the rivet holes on the nose ribs:
http://www.aclog.com/rv-9a/images/Em...p/DCP_1446.JPG
I fluted between the rivets holes on the main ribs as well.
Hope this will help.
Mike Hoover
Columbia, SC
www.eaa242.org/
N194MH first flight on 08-26-12
Old 10-21-2013, 06:33 AM
Mike...Are those the HS ribs? They look like the wing ribs.
Jimmy Black
RV-9A
HWY
VAF paid 2019
Old 10-21-2013, 10:46 AM
mikehoover's Avatar
Yep those are HS ribs (circa 2003, not sure if Vans changed the looks of them.)
Mike Hoover
Columbia, SC
www.eaa242.org/
Old 10-21-2013, 01:22 PM
I looked at other builder logs and it looks like they have cut more notches in the nose ribs and main ribs for the HS. Between each hole for the skin there is a notch cut which makes it easy to straigthen without fluting with pliers. There are also several ore notches in the flange on the HS main ribs also.....Its like they come up with a better idea for these part and straightening them. A little concerned I do not see the ribs I have on other web sites.
Jimmy Black
RV-9A
HWY
VAF paid 2019
Old 10-25-2013, 08:57 PM
AF_Alan's Avatar
AF_Alan AF_Alan is offline
Default use the pliers
My ribs circa 2007 look like Mike's. No extra notches required. My original (used) pliers had a fat head (model fp10 i think) which created wide flutes. Others create narrower flutes and fit easily between the skin holes. Check out Avery model 500 as one example.
Good luck
Alan
RV-9A N984AW
