Old 08-30-2006, 10:38 AM
jferraro17's Avatar
jferraro17 jferraro17 is offline
Opulence, I has it...
Default Capacitive System Bushings
Does anybody have a solution to "notcihng" the bushings for the capacitive wiring? I've tried drilling, X-acto knife, utility blade, and can't quite get a notch I am satisfied with/that is uniform.
Any ideas? Ever notice the things that seem like they will be trivial are always the biggest pain in the rear?
Thanks--
Joe
Joe Ferraro
DFW, VAF #17
SOLD
Old 08-30-2006, 10:45 AM
TShort TShort is offline
Ditto ... I am on my way to the shop this afternoon to do the same thing!
Thomas
Thomas Short
KUMP - Indianapolis, IN / KAEJ - Buena Vista, CO
RV-10 N410TS bought / flying
RV-8 wings / fuse in progress ... still
1948 Cessna 170 N3949V
Old 08-30-2006, 10:55 AM
mlw450802's Avatar
mlw450802 mlw450802 is offline
Thanks--
Joe
I used a rotozip sheetrock bit in my dremel on low to medium speed. I stabilized the dremel by clamping it to the work bench and held the bushings in a vice grips tool to keep them stable. It worked pretty well but the thing cuts pretty fast, so go slowly.
-mike
Michael L Wilson
Resuming building after a 4ish year hiatus! (life got in the way)
N194MW (reserved) RV9A SB
VAF# 148
Payson, AZ
Old 08-30-2006, 10:56 AM
RV7Factory's Avatar
RV7Factory RV7Factory is offline
Chief Obfuscation Officer
Two possibles.... A) Dremel tool or B) needle file.
Edit: D'oh, Michael beat me by seconds!
Brad Oliver
Livermore, CA | RV-7 | SOLD
RV-7: RV7Factory.com | iPhone app list: AviatorApps.com | Photography: BradOliver.com
Old 08-30-2006, 10:57 AM
vmirv8bldr's Avatar
vmirv8bldr vmirv8bldr is offline
Default Got a dremel?
I used one of these babies in a dremel tool. Works VERY well. I've used this bit on the bushing, and also on the tiedown hole in the skin and the Gretz Pitot cutout in the skin. Pretty easy to control, cuts very well. Excellent bit to have in the tool box.
http://www.dremel.com/DremelCMS/Pop-...?I=66267&tab=1
If that doesn't work, go here:
http://www.dremel.com/en-us/attachme...=66237&I=66267
Bart Filipiak
Eastvale, CA
RV-8 N74VB
Barrett IO-390
WW200RV
FLYING!!!!!!!
Old 08-30-2006, 11:29 AM
AltonD's Avatar
AltonD AltonD is offline
I tried the file, it was taking to long. This plastic is really hard.
DREMEL! If you do not have one of these, you are missing out on a great time saver. One suggestion though. chunk the cut-off wheels that are supplied with the package. They are dangerous when they fly apart. Use the reinforced cut-off wheels, (#426).
Alton DeWeese
N526RV RV7A Tip Up, IO360 180 W/Hartzel BA prop.
Flying ~950 hours since Aug 2010
N4IDH
Construction Log
?The secret of getting ahead is getting started. The secret of getting started is breaking your complex overwhelming tasks into small manageable tasks, and then starting on the first one.?
?Mark Twain
Old 08-30-2006, 11:39 AM
jferraro17's Avatar
Thanks Guys.
I have a really nice Dremel set, but it never seems to come to mind when I think of my tools on hand. I need to bring it into my bag of tricks more permanently!
Joe
Joe Ferraro
DFW, VAF #17
SOLD
Old 08-31-2006, 09:57 AM
jrouault's Avatar
jrouault jrouault is offline
I had good success using a hot soldering iron with a fine tip.
